New Kubota 7060 HDC
/ New Kubota 7060 HDC #1
kgevans
Member
spaulding, OK
Kubota 7060 HDC, Caterpillar 226 skid steer
Finally broke down and bought a Kubota tractor. SIL and I went together and bought 7060 with cab, loader, third function and dual remotes. I have had Case, Ford and Massey over the years, all open station. I guess I'm getting old and soft. Merry Christmas everyone. :)
/ New Kubota 7060 HDC #2
Congrats; Merry Christmas to you. You'll love the cab.
/ New Kubota 7060 HDC #3
Congratulations on your new tractor. I like my M7040 HDC very much. One word of caution be sure cab doors are closed before allowing tractor to move. This is speaking from experience as I've had to replace a shattered door from not closing it before I let clutch pedal out.
/ New Kubota 7060 HDC #6
Congratulations on your new tractor.:thumbsup:
/ New Kubota 7060 HDC #7
Congrats on heck of nice investment...looking forward to action pics.
Sometime this week. They have to install 3rd function. Couldn"t resist major discounts and 0%.
/ New Kubota 7060 HDC #9
Did you get the 12 speed or the 8 speed tranny?
Either way it's a great tractor!
8 speed. For our purposes it will be adequate. Mainly to be used for road maintenance, spraying, and tilling. Will do some rotary mowing and loader work on occasion. I will have to adjust to the tier 4 demands of this new tractor, but it seems to be relatively problem free.
/ New Kubota 7060 HDC #11
That is considered one of the best models Kubota makes, especially with a cab. What a wonderful, powerful and useful tractor.
Remember to check the front axle and front hub oil now and after a few hours. For whatever reason, they all require more as you get a few hours on them. Some a lot more even though the dealer checked them. The axle is easy to fill but the hubs harder. You either have to take the front wheel off for best access or use a squeeze bottle --like for ketchup--to fill. I did the bottle but should have taken the wheel off. When you check the front hubs, don't lose the copper washer under the plug. It should stay stuck to the hub.
Please post pictures.
Thanks for the tip on the front axle. I will check that after a few days. I will post pictures when we take delivery. We are also getting a little 6' rotary cutter, 300 gallon sprayer, 4400lb forks, and a RBT 3596 hydraulic blade. I'm too lazy to get off and change the angle of the blade anymore. We will get a 10 or 12 foot rotary cutter later next year.
/ New Kubota 7060 HDC #13
You might also need some rear wheel weights if you lift much heavy stuff. Assuming it comes with cast wheel centers, adding two weights to each side will take care of things. It's "bouncy" otherwise. I think they are 168 lbs each weight. Weights are around $300 a pair times two = $600. Chump change for the joy it creates.
It does have the cast wheel centers. We seriously considered a JD 5075E, but didn't like the loader movement. The Kubota has very precise loader movements. Most of the loader work will be limb shearing and brush removal. Nothing really very heavy. I have a Cat skid to do heavy loader work.
/ New Kubota 7060 HDC #15
If you didn't get skid shoes with the rear blade, add them to the order. They truly make life easier. :thumbsup:
/ New Kubota 7060 HDC #16
Congrats on the new tractor!!!! Anxious to see pics of course!!!
I agree with others that you'll want to consider additional rear wheel/tire weight. Especially if you use a Grapple or tree shear.
My M9540 has rear cast centers, one cast weight on each side and tires filled with fluid. No problems if just using the FEL bucket. Add Grapple chores and it becomes light in the rear.
/ New Kubota 7060 HDC #17
Congrats, on your new Kubota, looks like Santa saw someone was extra good this year, Lol. Enjoy your tractor. Merry Christmas.
DevilDog
Thanks for the tip on skid shoes. We don't have much snow, but I have wished for them in the past to save my gravel.
/ New Kubota 7060 HDC #19
You will way happier with the M7060 and I compare both on an almost daily basis. You may need those four rear weights to be fully blissful, however.
/ New Kubota 7060 HDC #20
Getting the skid shoes has nothing to do with snow. I have plowed snow once in my life. It has to do with limiting how deep the cutting edge will go. While they can be set to have the edge 1" above grade, (for snow plowing) they can be set to have the cutting edge even, 1" down or 2" down. And of course if the ground is very soft they will just sink. But after doing without for several years, it sure was nice to get them with this blade.
And it's not like you can't work without them, it is just much much easier with them.
