Loader Fork Carry All
/ Fork Carry All #1
tracydj
Bourbon, MO
Mahindra 2538
Attached are some pics of a carry all I made for my 2538 fork attachment. It is made out of treated 2x6 and 4x4's. It measures 6' x 4' and I have $120 in materials in it. I debated welding a steel frame but I wasn't going to end up saving much on weight. The total weight is right at 420 lbs. I have some u brackets that I will attach to the back so that I will be able to dump. Once I get those on I will see if I need a channel on the bottom for the forks to slide into.
/ Fork Carry All #2
Thank you for posting. I'm going to be making something similar soon. It looks like you used some type of lag bolt- can you expand on the fasteners? Also did you use any type of glue? I don't know what sticks to the PT wood.
Looks good!
/ Fork Carry All
Looks good!
I didn't use any glue or liquid nail just the structural wood screw. They are $33 for a box of 50 but unlike a bolt you don't have to pre drill which is nice. I am going to use 4 of the u bolts to secure through the back 2x6 to the forks. I plan on leaving the carry all attached to the forks most of the time.
/ Fork Carry All #4
View attachment 492575View attachment 492576View attachment 492577View attachment 492578View attachment 492579
3Pt Carry all is a fixture on the back of my Max28, just so handy, Photo's in this link below
http://www.tractorbynet.com/forums/...loader-curl-possible-solution.html?highlight=
/ Fork Carry All #5
Thanks for the info. Looks good!
Merry Christmas
/ Fork Carry All #6
Thanks for the photos...I made one this fall. I added 2 inch conduit to hold shovel and rake. I also added 4 caster wheels on the bottom so I can move the unit without the use of tractor in storage.
4004SFL (A59228)
4004SFL (A59228)
15200 (A56857)
15200 (A56857)
2006 Ford E-350 Enclosed Service Van (A61568)
2006 Ford E-350...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
