Counterweight box
/ Counterweight box #21
Hopefully you can get this balancing act worked out. If you can, you'll be surprised what your 2wd tractor will do. For decades farmers used 2wd with FEL to do all their loader work.
/ Counterweight box #22
I have an MX5100 and often use implements that weigh 800, 1050 and 1200lbs. For me, either 1050 or 1200 lbs is all that tractor would want. For my tractor, 2,000 lbs would be way too much.
/ Counterweight box #23
My box, total weight including concrete is just approximately 500 lbs and balances nicely on my B series. Welded a receiver hitch at the bottom and as others have suggested mounted PVC for holstering rakes and or shovels
Have you weighed the box? I calculated the volume of that B8160 box and it would hold about 650# worth of concrete or 500# of sand (the 500# number is inline with Kubota's rating for sand). Then add another 100# for the weight of the box itself. So you'd be at 600# for sand or 750# for concrete, minus any loss due to your PVC tubes.
I am planning to weld a receiver too. Looking to do it internally to tie into the pins and top collar, and have the receiver poke out the back.
/ Counterweight box #24
Is your tractor 2wd also?? Can't remember??
/ Counterweight box #25
Bought 15 bags of 80lb quickcrete and a quart of Kubota Orange this morning going to start there and see how it ends.
If you have a rock pile, mix a little and throw rocks in, then mix a little more and throw more rocks in. Saves concrete.
Don't make the mistake I did. I made a 1500# box but then felt it was to heavy, so now my neighbor with a bigger tractor has a free weigh box.
/ Counterweight box
What tractor you have?
/ Counterweight box
I live in the coastal plain so no rocks at all but I do have some busted block and brick now that you mention it.
/ Counterweight box #28
My 2 cents, If you plan to leave the counter weight box outside. Don't put PVC pipes in unless you drill out the bottom. Mine filled with rain water... same goes with space at the top, you'll have a puddle in there.
Looks like it was a fun project...
/ Counterweight box
Yeah I'm defiantly going to drill some weep holes right at the concrete level when I'm satisfied with the weight although I don't keep much of my stuff outdoors.
Here it is with 13 bags of 80lb mix in it I won't be able to test it out until I feel confident it's cured enough to hold itself up and I'm not anticipating being able to move it until the LA1065 comes in.
/ Counterweight box #30
I put scrap brake disk/drums in the bottom of my old 60 gallon air compressor that got a leak. Bottom 1/3rd or just up to the toplink was filled with cement to lock the 3pt parts in better & cover the scrap. The rest was filled with dirty sand.
/ Counterweight box #31
Years ago I had a counterweight barrel and filled it with old pieces of steel and bolts. I could add or subtract if the situation warranted and it worked great for me.
/ Counterweight box #32
Your gonna love having the space on top to put stuff.
/ Counterweight box #33
I have not weighed the box, but I put in only 400 lbs of concrete which when you add the aprox weight of the box would come out close to 500 lbs. Yes I do have weep holes in the bottom of the PVC and the box so if it does get wet water will drain out the bottom of the PVC
/ Counterweight box
Update hooked the tractor up to it for the first time and it picked it up no problem. I can deadlift the front end of the tractor and judging from what I can do in the gym I'm thinking I'm around 200lbs on the steering axle right now. I've got it in the shop ready to spray tomorrow and I have a piece of old 1/2 conveyor belt big enough to cover the concrete.
/ Counterweight box #35
That'll all change when you bolt on the FEL.
Nice looking rig!!!!
/ Counterweight box
Yep I'm pretty happy with it as is but I'm only around 1200 lbs far less than the 2000 I was aiming for. I'll have to see how it responds with the loader installed.
Moving this behemoth magnolia will be the first test.
/ Counterweight box #37
I think you'll be able to add some more weight to the box. An FEL puts a LOT of weight on the front tires.
/ Counterweight box
Got the paint on it this AM had a heck of a time with my spray gun I thought I cleaned it real good last time I used it but apparently I was wrong.
/ Counterweight box #39
What would you use to weigh the box?
6062 (A61165)
6062 (A61165)
1995 Chevrolet S10 Pickup Truck, VIN # 1GCDT19W7SK120441 (A61165)
1995 Chevrolet S10...
John Deere 4044M (A60462)
John Deere 4044M...
iDrive TDS-2010H...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
2005 INGERSOLL-RAND WL-350 WHEEL LOADER (A62129)
2005...
