So I busted my curl cylinder ... can't find parts to fix it
   / So I busted my curl cylinder ... can't find parts to fix it
I can't imagine that you damaged both cylinders at the same time on a relatively new tractor. I would first check all your hoses and hose connections... Might have had a pressure overload pop a hose fitting or connection.
The way these cylinders are hooked up ... if one cylinder fails the other one won't move at all is my understanding. Do I have that wrong?
I did have like a drop or two on the fittings of what I think is the offending cylinder but no busted hoses etc. At first I thought maybe I took out a "shock" valve but I don't think these little tractors have anything like that ... I think it's only bigger more expensive machines that are equipped with stuff like that.
   / So I busted my curl cylinder ... can't find parts to fix it #12
To me, it sounds like you are low on hydraulic fluid and have an air gap in the line. With all cylinders filled, you might have emptied the reservoir. Check the dipstick and put a gallon in it and see if it recovers.
   / So I busted my curl cylinder ... can't find parts to fix it #13
you broke what I call the puck off of one of the cylinder rods. if it was held on by a big nut you can drill and tap a hole in the rod and install puck with a bolt. use a fine thread allen head bolt
Hmm, so this looks like a 'minor' problem:
It rained the night I broke it and was quite muddy from several days of rain but I was finally able to get to it and tear it apart today. I followed the advice to try and pull the rod out first before going too far. The cylinder I thought was the culprit wouldn't pull out. Did the same thing on the other one and sure enough it pulled right out!
It's the cylinder on the right side with the bucket level indicator on it.
Took to my local hydraulic shop and we tore it down and found the nut and inspected everything. The part left in the nut is at a funny angle. The threads on the rod looked funny to me. It's like where the threads start is not perfectly centered on the rod. There is a small flat that is offset then the threads start. If you look at the picture above where the view is down from the top of the rod ... the flat I'm talking about is on the top. That's not the camera angle.
You can actually see wavy metal in the bore where the bucket level indicator bracket is welded to the cylinder.
So local shop said the rod can't be fixed. Said the piston and seals all look good through and the inside of the bore isn't scratched up and they checked the rod on a trued surface and it looks like the rod is good too (well, minus the end that broke off).
They told me of a shop that can duplicate the rod so I'm going to make a trip to see them tomorrow and see what they say and get a quote.
I called my dealer and sent them pictures (they are not close by) and copied LS HQ. It sounded like they would quote me an entire cylinder but I asked if it was possible to just purchase the rod.
If the broke one is repairable, I'm going to have my local shop repack both so they preform the same. They have about 610hrs on them.
whis, interesting idea on drilling/tapping the rod. I'll ask about that option with the people I meet tomorrow. It looks cast to me so that probably rules out welding it etc., but I didn't think of drilling and tapping it.
   / So I busted my curl cylinder ... can't find parts to fix it #15
we did that on a loader about 5 years ago and it has held up fine. it is used almost every day with a grapple doing brush clean up for tree service and i promise it is not babied it has the snot worked out of it. all they need to do is put in a lathe and turn the rest of the threads off and then drill and tap we did fine threads and used loctite
I know a guy that owns a local CNC shop. He's done lots of projects for me in the past. If anyone can make a hole concentric he can. Plus he's close by so after consulting all the hydraulic yoda's I'll show it to him and see what he says. Something tells me that would be the cheapest fix but sometimes his shop gets real busy and I have to wait for some idle time ... he's not going to shut down the expensive machines in a middle of a run for a 'one of' for me :)
We have a hydraulic place near my work, I can take a cylinder apart and take my parts there and they can match them up to a kit or make me one. If you do that you shouldn't have a problem locating your parts.
Hydraulic shop acted like everything they found in there were common seals etc., which is what I was hoping for. They see and fix a whole lot more cylinders than my not-so-close small dealer.
Last week my co-worker who has busted a few cylinders on his backhoe (catches the bucket on the ground when going up a hill) brought in a piston for show and tell. It was pretty large and looked aluminum. Had a single channel milled around it where a seal went. The root of that channel was fractured and the lip/edge of the piston lifted up and the pressure forced the seal through the fracture in the metal! Pretty cool looking.
The piston on this curl cylinder didn't look aluminum and had several seals around it. I'll try to get pictures of the guts and post them. When I was at the shop we were kind of busy and had hydraulic fluid everywhere so I didn't think to grab the phone for pics.
   / So I busted my curl cylinder ... can't find parts to fix it #19
Yep, easy fix for hyd shop
Cool video!
I went to the place that makes rods today. They said it would be $30-$40 in material plus about two hours of labor so around $150. I found out I can order a new rod from LS for about $58 so I went that route and ordered it today.
Also noticed the threads/nuts on the two cylinders rods are different. I found the .pdf of the left LH cylinder parts list and it lists the part numbers of the nut as being the same so something funny has gone on at some point. The nuts look different in physical appearance too besides the threads being different.
Left hand parts list:
View attachment LL3101-Bucket cylinder LH.pdf
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
