New to me DK45SE
/ New to me DK45SE #1
daveborg98
Tulsa, OK
Kioti DK45SE HST
I am quite new here and am purchasing my first tractor. I found a deal for a 2010 DK45SE with 170 hours for $16,500. I am heading to pick it up Thursday. It is a little more than I really need but bigger is always better right?
Anyways, since this is my first tractor I am wanting to know what to look at before putting it to use. I know to check fluids and such but what else? Are the items specific to Kioti that I need to pay attention to and check? I have tried to search but I think my google wand is broken.
I am sure I will search a ton on here and ask many questions.
/ New to me DK45SE #2
With only 170 hours, there shouldnt be much wrong with it. Mine has 650 hours, and only a few minor bugs over the years. Its also a 2010.
Id probibly do a complete oil and filter, hydraulic, fuel filter change just to be sure. Never know if previous owner did any maintenance.
/ New to me DK45SE #3
+1 Everything else should be okay
/ New to me DK45SE #4
In addition to the above, I would check all of the wheel bolts and loader mounting bolts, and the little pesky bolts on the loader itself that hold the grease zerk fittings on. They often loosen up. And Kioti specific is the bucket level indicator, as its bolts tend to loosen up and you will "wad up" your bucket level rod. Check your hand throttle tension. If it suits you then all is good, but if it is too stiff, then you can read about it here
http://www.tractorbynet.com/forums/...ottle-lubrication-pix.html?highlight=throttle
/ New to me DK45SE
Thank you guys for the responses. I till make sure to check the things mentioned.
Now to start using the search and figure out which fluids to use. I assume it is quite like a car and everything swears by what they have been using.
/ New to me DK45SE #6
Do you have a owners manual?
/ New to me DK45SE #7
At 170 hours most components would be hard for the previous owner to mess up from a maintenance standpoint. I agree with everything above about things to do once it's in your possession.
A few things I would do since it's a private party. Look at the house, shop, yard and other vehicles- does this person care about his stuff? Look at the underside and grill for damage. Ask if he used it or he had others using it for business. Is the loader bent or damaged- does it raise and lower evenly? Is the bucket damaged from lifting heavy loads with chains etc. Does the 3 point show damage? Does the frame and loader frame look good?
98 out of 100 this is a solid machine that will provide years of use
1 out of 100 this was used by employees who didn't care about the machine- this should be obvious though
1 out of 100 he did something to the machine that bent or damaged a major component. If you take your time, look at everything and run everything you should be able to sniff this out as well.
Again odds are in your favor this will be a great purchase!
/ New to me DK45SE #8
The owners manual will show the Kioti approved fluids. I used one of those the MobilFluid 424. There are several on the list. I just used Rotella 15W40 for engine oil, but if you live in a colder climate you may want something else. Ok, see you are in Tulsa, so should be about the same as here in Branson.
This little PDF chart may be of some value to you:
View attachment Kioti_Fluid_PSB.pdf
/ New to me DK45SE #9
OH, and Dave, welcome to the forum, and welcome to the Kioti pack".. :thumbsup:
/ New to me DK45SE
Murphy1224 - I do not think the owners manual is with it. I may be wrong but I will know for sure on Thursday.
RNeumann - I will make sure to look those things over. It is actually not private party but from a small dealer in Strafford, MO. They originally sold it to a guy that ended up moving to town and selling it back to them. So I am the second owner and it was sold both times by the same dealer. I am going to ask them a few questions on the maintenance to to get a better feel for where everything stands.
K0ua - Thanks for the welcome. I really like this forum so far. Also, thank you for the PDF link. That will help a lot especially if there is no manual with it.
On the engine oil, do you guys find it best to run oil for what the temperature is 80% of the time? It Tulsa, it is usually over 32F with the exception of a few weeks to a month of time. Would it be alright to run the 10W-30 year round?
/ New to me DK45SE #11
Would probably be fine.
/ New to me DK45SE #12
K0ua brings up good points, especially about the loader bolts. I have an acquaintance who did not check his LS loader bolts often and snapped one off. He ended up having to take it to the dealer for repair. I do not have my manual handy but seem to recall we are supposed to torque every 25 hours of use. Someone will post with the correct hours, I imagine
Mine were always loose enough to bother me. Somewhere ~ 150 - 200 hours I replaced all of my FEL mounting bolts lock washers with grade 8 and as many bolts I could find local replacements for- plus used blue thread locker. Still had loosening bolts, just not as bad. I torqued them the other day at 350 hours and most were still snug (finally) but had a couple that required 1/8 turn or so. Some folks seem to have pretty good luck with the FEL bolts and others not so much. I used my loader to the maximum digging rocks and stumps.
/ New to me DK45SE #13
My loader and wheel bolts seemed to have quit stretching or paint wearing in after about 125 hours. I would suggest checking and snugging them every 25 hours or every other greasing of the loader which you should do after 10 hours of loader use. Yes, snapped off loader mounting to frame casting bolts is not something you want, nor is "egged" out wheel holes from not checking wheel nut/bolt tightness. Like any piece of machinery, tractors require some maintenance. You can either do it and have trouble free operation, or you can forget about it, and put undue wear and breakage on the machine.
/ New to me DK45SE
I fully agree with the "ounce of prevention" thing.
Are the torque specs critical or just "very tight"? I am assuming that this info would be in the manual it is comes with one.
/ New to me DK45SE #15
Without digging out my manual I seem to remember the rear wheel bolts were about 160 lbs and the large loader bolts the same, I think the front wheel bolts were about 80.. But best look them up in the manual. If you don't get one, we can research it. Get back with us when you get the machine and have had time to take some pictures for us to admire. We will help you out.
/ New to me DK45SE
Thanks guys. I will report back when I have it in my possession.
/ New to me DK45SE #17
Talk to that dealer. Find out if he did the maintenance and, if so, what and when. The hydraulic fluid may be OK if you KNOW it (and the filter) was changed at 50 hours and replaced with the right stuff.
Engine oil/filter changes are more frequent. Be sure to use Diesel (C-rated) engine oil; many of us use synthetic motor oil (like Mobile 1 or Rotella T6), mainly for easier cold starts. But synthetics won't extend engine oil change intervals with these small Diesel engines (changing oil is how soot is removed).
Get an owners manual for your specific tractor; any Kioti dealer can order one for you. You really need to have and read that little book.
A paper parts manual is unnecessary; there are several good online parts sites sponsored by dealers (like MIE).
Many of us also want to have the maintenance manual. The newer ones (like the SE) are quite good but there are still some errors and typos. There is a soft-copy version of the EX (export) maintenance manual on some foreign web sites. I think the US SE version is very similar to the EX model.
/ New to me DK45SE #18
If you don't get the paper owners manual, let me know...send me a PM
/ New to me DK45SE #19
Speaking of checking bolt torque, should you loosen the bolt first, then torque, or just check to see if the bolt is tightened to the torque setting?
/ New to me DK45SE #20
I think this is an excellent question and any machinist on here can probably provide the correct answer. My knee jerk would be to loosen and retorque would be the best way to do it for the most accuracy. However, I just check the torque as the fastening sits without loosening first.
Found this: Can you use a torque wrench to inspect a bolt for proper torque? | AMT Community
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
White 5100 12R 30" Planter (A66285)
White 5100 12R 30"...
2015 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59914)
2015 FREIGHTLINER...
