Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #4,121
What was the program on your phone that you used?
The wood was cut and split back in the summer. I laid in a pile until I stacked it a week or 2 ago. I have not checked the MC of it. I've seen charts ranging from 3485 to 3950 per cord. The pallet actually had over 70 cubic feet on it. So depending on the MC and what chart you want to go with my 2200lb for the wood may not be off much. If you go with 3950 per cord it would be 2133lbs.
Firewood Weight - Chart and Information
/ Tractors and wood! Show your pics #4,125
http://i851.photobucket.com/albums/ab80/eriksat1/Wood ID/LogTruck2008005.jpg
Ok, the reason I figured 10 cords as they used to sell one of these as 9 or 10 cords. So I imagined that pile being loaded on one of these. I use to log for a while , then went on mechanical harvestor for a couple years. Now just firewood. Liked the work but no money at the time. I used to get paid $14 on the machine, and $28 a cord with the chainsaw. Of course, most of the wood was small in size. Anywhere from 3 inches to maybe 12 inches, but only 3 lengths of 8 foot wood. Of course some area's were better, but most of the great wood was cut before my time, here in Newfoundland.
/ Tractors and wood! Show your pics #4,126
With the thermometer dropping rapidly, hauled another load of firewood in to keep us warm.
The knarly sections of hard maple can be dificult to stack so I came up with an idea for an
open-air storage cage for the "chunks". Used some scrap lumber that was on hand and it
made for a very sturdy and efficient way to stack and air dry the chunks by the wood boiler.
Measures 48x22x7ft tall. Holds a lot of chunks!
/ Tractors and wood! Show your pics #4,127
I happened to visit friends at their new home and noticed it came with a BUCK stove... I commented and the wife said they are getting rid of it because it doesn't work... lots of smoke and the wood would not burn hardly at all...
They did not open the damper and used wood from a branch that dropped a few weeks prior...
I'm not an expert but it sure seems a lot of common life skills have been lost...
/ Tractors and wood! Show your pics #4,128
What's a damper?
/ Tractors and wood! Show your pics #4,131
It pains me to say but this is why we have the regulations we do like blanket no burn days even with certified low emission cat wood stoves.
Too many otherwise successful people that lack in common sense...
/ Tractors and wood! Show your pics #4,132
I recall many a time in our house when someone would start a fire in the fireplace and promptly fill the house with smoke due to not opening the damper. At least a couple times a year, if not more.
/ Tractors and wood! Show your pics #4,133
My Dad had a hard time remembering if it was open or closed... until it was too late.
In the rentals I have made it so the dampers cannot be all the way closed for fireplaces and the air not fully choked off for the stoves...
/ Tractors and wood! Show your pics #4,134
My neighbor ( since passed ) use to burn his garbage in his wood stove. Including the plastic. Any mention of air pollution was forbidden. He did listen to my wife when she said it stinks....
/ Tractors and wood! Show your pics #4,135
There are a lot of folks out there who either deny that pollution is a problem or simply don't care.
/ Tractors and wood! Show your pics #4,136
Keeping the trail clear and clearing brush.
/ Tractors and wood! Show your pics #4,137
The first fire we made in the fall of 2015, I opened up the fireplace doors, opened the outside air intake damper, and opened the chimney damper. But by "open" I mean I flipped all of them to the opposite direction of what they were, because I specifically remember "closing" all of them earlier in the spring.
I don't know what they heck happened, but apparently the chimney damper had actually been open (all summer long) and I really closed it. Couldn't get a fire going, smoked up the room, etc, until I physically stuck my head inside the fireplace to look up the chimney and realized the damper was in fact closed. Boy did I feel stupid. But at the age of 46 I learned that "opposite" is not necessarily the same as "open". Still don't know why that damper had been open all summer. Either I forgot to close it as I thought, or maybe my wife flipped it at some point and didn't tell me.
/ Tractors and wood! Show your pics #4,139
The funniest thing I remember about the damper is when it wasn't closed and a flying squirrel came down the chimney and ran out of the fireplace one summer. We had vaulted ceilings. It would run up the wall to the peak, jump off and glide across the living room, then do it again from the other side. Once it landed on my sister's head! HAhahhaahaa, man did she scream! It was a fast little bugger. We opened the doors and if finally ran outside.
/ Tractors and wood! Show your pics #4,140
The first fire we made in the fall of 2015, I opened up the fireplace doors, opened the outside air intake damper,.
Speaking of outside air intake dampers in fireplaces, I have that setup with glass doors in my new place and want to retrofit the fireplace with a modern insert and SS flue. The wood stove place in town said they don't make inserts with outside air (crawlspace air) intake. Google indicates they need to be custom fit which makes 100% sense. A link I did come across poo poo'd the advantages of outside air as combustion air. Any opinions?
2011 Ford F-550 4x4 Terex Hi-Ranger LT38 38ft Insulated Bucket Truck (A61568)
2011 Ford F-550...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
