Do we need a warm garage....
   / Do we need a warm garage.... #121
Sometimes you guys scare me...:eek:
That remark about the pants came from real life experience. In college I worked part time in a truck body shop as a weldor. On one very cold winter day I was inside a chipper box (the kind they blow the chips into from a wood chipper) welding overhead. About half way through the job I felt something beating on my leg. When I looked down a coworker was trying to put out the flames billowing up from my pants cuff. I told him to knock it off 'cause I was just starting to get warm! :laughing:
   / Do we need a warm garage.... #122
You know those flannel shirts with the slick nylon or polyester or whatever lining in the sleeves??? That stuff is highly flammable!!!! Burned the crap out of my arm before I could get if off. Sortta melted to my skin...... Haven't worn long sleeves while cutting or welding since. I'll take the occasional small burn on a bare arm. :)
   / Do we need a warm garage.... #123
Wow, you took this thread about "warm garage" to a whole new level. This is one rare occasion that we can agree on "NO pictures please".
   / Do we need a warm garage.... #124
Gives a whole new meaning to nuts roasting on a open fire!:laughing:
I work mostly with metal. After ruining a couple hundred long sleeved shirts and twice catching myself on fire wearing lined flannel shirts, I go sleeveless. :D
I like working around 50-60 degrees with a shirt, I'd rather have the shirt take the abuse and get dirty. A little welding with a T shirt is ok for a while with small wire, but when doing serious welding, bare skin has to be covered, or arc burn will occur and that hurts pretty bad. When warring a shirt, should be all cotton or even better, something like a Revco shirt, you can look cool while working with heat.
Amazon.com: Revco Industries - Bsx Stryker Fr Welding Jacket - Black With Red Flames: Industrial & Scientific
   / Do we need a warm garage.... #126
Doesn't anyone wear leather when welding anymore?
Back in another life I was a certified welder and we all had a set of leathers with velcro for the turn up collars to keep from getting arc burn of the neck.
Proper attire was a requirement of the company with included steel toe and shank boots...
   / Do we need a warm garage.... #127
Finally remembered to get a battery for my infrared thermometer.
Temps of my stove
Top of barrel = 640F
vertical pipe between barrel and reclaimer = 370F
front face of reclaimer = 260F
vertical chimney pipe at elbow above stove = 220F
outside 10" chimney pipe just above T = 92F
Temps of my stove
What, where, how, and why does the pipe go out threw the wall instead of threw the roof, purpose of heat reclaimer, besides a 270F drop, which sounds impressive, where did you get it, how highs the shop ceiling? You must have better chimney pipe at 10", mine is only 8".
"Doesn't anyone wear leather when welding anymore?"<<<<<I wear leather bibs when welding overhead, then only if I cant get out of the way of the sparks, and always wear leather when carbon arc gouging on overhead. To reduce neck arc burn, I tape a small piece of leather on the welding hood, other then that full cotton shirts and at my work I also wear flame retarted coveralls, mandatory-ish.
   / Do we need a warm garage.... #130
pipe thru the wall = I've never understood why anyone would cut a hole in a perfectly good roof. I built a dual wall pipe thru the wall. My stove pipe goes thru that. No worry of too much heat at the wall.
purpose of heat reclaimer = the temp difference below the reclaimer and above the reclaimer is 150 degrees. Works pretty good huh. If you look at it there are round tubes that go thru the box. Behind the box is a squirrel cage fan blowing air thru those tubes. Thus reclaimer. I'm using that 150 degree heat rather than letting it escape up the chimney. I built it.
shop ceiling height = 10ft at the eave, 12ft in the center. Vaulted ceiling. All steel building.
chimney pipe size = I used what I had. 1/4" wall steel pipe.
The actual temp drop from the top of the stove to the chimney going out the wall is 420F degrees. Even with that I'm a bit disappointed that my outside chimney pipe is still at 92F degrees. But it doesn't soot up so I guess losing that heat is work it.
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
Super Material Lift MH1000 (A51039)
Super Material...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A50854)
2016 WINNEBAGO...
HEAVYEQUIPMENT ROLLS OF CONDUIT (A50854)
HEAVYEQUIPMENT...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
