Creosote "eating" logs
   / Creosote "eating" logs #11
How about it-anyone have any experience with those logs you put in your fireplace..."
Had the flue professionally cleaned by same guy I have used for years.. Also, the stove is 7 years old and this fall I replaced all the gaskets in it. What a difference-I am probably burning half the wood I did last season.
HOWEVER- I've been burning for about 3 weeks and Sat night before I went to bed I opened up damper, and air control to get a "high burn" to clear out any creosote. Well I went outside to check smoke and had about an 18" flame coming from chimney. Immediately closed down air supply and it dyed down. Usually you can expect a creosote buildup by end of season but after 3 weeks?? And I'm burning good seasoned oak!
Appreciate any opinions
Can't comment on the those creosote-b-gone logs as I've never used them. I sweep my chimney about three times a season. Once before start of season, once during season (Jan/Feb), and once in late winter/early spring when one tends to (barely) burn cold/oxygen starved fires or smoldering fires you keep going during the day just so you have some embers at night. Or if I notice a change in the normal amount of draft, I know I better clean SOON!
How would getting the chimney cleaned or replacing gaskets reduce your wood consumption by 1/2?
Sounds like you definitely had a "high burn". Getting a chimney fire like that after only 3 weeks of burning seems like a short amount of time for dry wood, especially so if your doing regular "hot burns". Like been said, maybe our sweep didn't clean top section.
Do you have a cap on chimney? I don't (but should). I think this leads to a cooler chimney (more creosote), especially when it rains/snows.
Does anyone know if a regular hot fire (but not so hot the creosote ignites) will "dry" the creosote so that it naturally flakes off?
Or what's is the chemical in those special logs?
In think the new gaskets allowed me to turn air control down and as no air was leaking in, my burn time was extended. Before I did the gasket replacement I would NEVER make it through the night on a load of wood. Now the downside, if say I was burning a load of wood in say 4 hours, I had a much hotter fire I would think-and correspondingly less opportunity for creosote to build up. so sounds like I solved one problem-using a lot of wood-but created another
No cap-but this is a center chimney-not exposed on outside wall-but house is typical "Early American"- like I said 10/12 pitch roof so while 30+ feet of chimney-basement, first and second floors is warm, there is 12' in middle of cold attic, plus the chimney extends 4+' above ridge. Those last 16+ ' allo[/B]w for plenty of cool down.
CR see my comments above.
   / Creosote "eating" logs #13
I think the new gaskets allowed me to turn air control down and as no air was leaking in, my burn time was extended. Before I did the gasket replacement I would NEVER make it through the night on a load of wood. Now the downside, if say I was burning a load of wood in say 4 hours, I had a much hotter fire I would think-and correspondingly less opportunity for creosote to build up. so sounds like I solved one problem-using a lot of wood-but created another
I think you're right. My problem this year is my wood is too dry (and too light). If I put too many pieces in the stove (or what in other years is a normal amount ), and have the stove turned down, it pretty much all heats up to combustion temp at once and want to GO!! If the air is turned down, the stove fire will start "thumping" / "breathing" / "backfiring" for air as it cycles between choking and then spontaneously re-igniting.
With more moist wood, or wood with a larger thermal mass that heats more slowly and burns in a more uniform fashion from bottom (coals) to top.
So the trick I use is to let it burn hot (short time) and use the thermal mass of my chimney and soapstone stove to extend the heat rather than trying to burn slow and steady (and "cold").
And if I do have to turn it down because things are getting too hot, I use the stove pipe damper more to smother/decrease the combustion, rather than trying to starve the fire of inlet air. - It definitely makes a difference if that makes sense.
Well guys, I took the stove down today. Called my chimney guy-of course no return call. So borrowed a pals cleaning rods and would you believe there was a blockage just about at the top. And instead of guessing, I did some measurements and guessing at the amount of chimney above the ridge, I came up with a distance of 37.5 feet from where thimble is in basement, to chimney cap. Significant dimension? 12 ft. of masonry in cold attic plus about 5' above ridge.
My guess is my "sweep" did NOT put last rod on (he cleans it from basement) and I started the season with less than a clean chimney at top.
Bottom line I will be less concerned about going through the night on a full load of wood and more concerned about running stove hot enough to avoid going through this again.
And I will try that Rutland powder product.
thx again to all for your opinions.
   / Creosote "eating" logs #15
I read up on that Rutland powder product. Turns out it's active ingredient is tri-sodium phosphate (TSP). Supposedly you can buy TSP for 1/4 cheaper in the paint prep section of most hardware stores. One user says add a tablespoon (or two) in a spray bottle w/ water and hit your stove with it every once in awhile when you think about it.
I might try this, ...but I won't trust it to replace sweeping! If it doesn't work, so what, I have a cleaning product for other uses.
Trisodium phosphate - Wikipedia
Thx CR-don't think I will be spraying it in stove but I think the Rutland peoduct just calls for you to dump the powder on hot coals-so if ijn fact it is a "rebrand" of TSP, sounds good
   / Creosote "eating" logs #17
I've been using the Rutland Kwik Shot tubes for probably 15 years or better, I toss the whole tube in the woodstove on a good going fire about once every week or 10 days. The little dab of plastic tube it's in is gone in 30 seconds. I have an airtight stove and an external masonry chimney 16' tall and I run my stove at lower temps a lot so creosote is a problem. The chemical is simply to convert the liquid creosote into fluffy, flaky creosote so your brush will remove more when you brush, which I normally have to do about every 3 to 4 weeks during the season. I usually get about a gallon bucket full of very light & fluffy creosote each time. My firewood is oak, cherry, walnut, elm, hickory cut with the sap down and all seasoned at least 2 years or better and fully dry under tarp. The creosote is strictly from me running the smouldering fires and a cold, masonry chimney but that's the way I like to use my stove and I'm willing to do the maintenance necessary to do so. I know people in this area that can burn all season and never have a lick of creosote problem but you go visit them and it's 110 degrees in their house and 2 or 3 windows open !!
   / Creosote "eating" logs #18
I worked in a hardware store a long time ago that sold CSL logs and I believe the active ingredient was calcium chloride
Sometimes I would throw calcium chloride into my fires. Don't know if it worked but it made pretty colors when it burned
Well here is an update. I bought a tub of the Rutland powder- I think like 8 bucks in Tractor Supply. Been dumping a tablespoon in a couple times a week in AM when I have a bed of hot coals. This since I first had my problem. A week or so ago I pulled the stove pipe that connects stove to Thimble/ flue. I actually could see the red clay of the flue! Have never seen it so clean!
Will see how much creosote comes out-and if in fact its "powder" as they claim you will get when I take the stove down for cleaning in another month. so far so good.
Payment Terms (MUST READ) (A50774)
Payment Terms...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
