ldowney
Member
Hey guys. I'm adding a 7 ft. snow plow (pictured below) with the quick attach mount to my Kubota L4060 tractor. The plow has two hydraulic cylinders with two quick connect hose ends on it. What I'm wanting to do is connect the snow plow and set my curl angle of the blade. Then disconnect the two curl angle hydraulic lines. Connect with extension hoses, the two lines coming from the snow plow. This way I can still raise and lower my plow and also using the side to side motion of my stick, to turn the snow plow from left to right.
I called my local Kubota dealer today and they said that wouldn't work. I would need to add a $1,100 3rd function system for it to work. As little of snow that we get here in NC, I'm not wanting to invest $1,500 for the plow and another $1,100 for the 3rd function.
Is anyone out there, other than my buddy who told me this works just fine on his Kubota M series tractor, doing this method? Seems like it would work just fine to me. Suggestions? Concerns?
Thank you.
Thank you.
