FEL how long 'should' bucked remain up when parked?
   / FEL how long 'should' bucked remain up when parked? #131
The "correct / not-corrct" list wasnt meant to offend anyone. Rather it was to help me keep track on just who undersotod and who did not, in an effort to try to help teach those that do not understand how things actually work. And at this point, I still dont really know where you stand Richard?
Yes, loaders drift down all the time. Some worse than others, and several threads on TBN about the subject. But the issue always comes up when someone says something like "the cylinder probably needs rebuilt" or "cylinder seals are bad" etc.
And thats just plain bad advise. And some people just cannot comprehend that the seals in the cylinder being bad, cannot and will not be the cause of a loader drifting down. And after many many threads and posts on TBN about the subject, the bad advise that people are giving, telling people to rebuild their cylinders keeps getting spread around.
A FEL control valve is supposed to have minimal leakage past the spools. And thus minimal leak down of the loader. When the valve wears out, it leaks by more and more, and the loader drifts down faster and faster. Has nothing at all to do with the cylinders, cylinder seals, etc.
   / FEL how long 'should' bucked remain up when parked? #132
I agree.
Nowhere in this entire thread can you produce a single comment I've made that would say otherwise.
And you can leave my name on the "Not Correct" list. I like it there. :cool:
You might want to watch what lists you end up on this time of year.:cool:
   / FEL how long 'should' bucked remain up when parked? #133
I just don't tolerate poor observations and half truths being passed off as information...
It's a weakness I have, the desire for accurate information and advice. That is a problem for some folks.
I'm working on it.
And isn't that exactly what you did?
No answer for my question and picture above?
   / FEL how long 'should' bucked remain up when parked? #134
Heck Murph, I can't even talk to you about the weather!!!! It's you Ohio guys that ruin it for the rest of us!!!! :D
   / FEL how long 'should' bucked remain up when parked? #135
Just so you know... its snowing here again.. keep that secret though..
   / FEL how long 'should' bucked remain up when parked? #136
So you maybe you should have had an undecided list???? ;)
I only made one comment and that was response to a statement that was off the subject of the thread title. :D
   / FEL how long 'should' bucked remain up when parked? #137
You can keep that stuff. We are dry and cold. Should see negative zero numbers in the next couple days.
   / FEL how long 'should' bucked remain up when parked? #138
Yep, more surface area as well as more volume. Which is why the cylinder has more force extending than retracting. Also why its slower extending than retracting. Its all directly related. IF you understand one part of it, you should be able to understand it all:thumbsup:
The following 4 still need to understand
Ray66v
OVRSZD
ch1ch2
rd_macgregor
I got it now!
There was no way in heck I could be wrong! But, I was. The piston could move inside the cylinder with a leaking seal as I believed, if it was not pulling in the rod to which it is attached, from the outside of the cylinder. The addition of the outside rod into the inside of the cylinder is not possible.
My brain block is removed.
   / FEL how long 'should' bucked remain up when parked? #139
Post 33 and 41 were the "call for reason",expressing a continued theme of misinformation.
   / FEL how long 'should' bucked remain up when parked? #140
What's that got to do with me?
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
UNUSED SDLANCH SDLC1220-12' X 20' CARPORT (A57193)
UNUSED SDLANCH...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
2020 MACK P164T (A58214)
2020 MACK P164T...
