oak extensions for chain hoist
/ oak extensions for chain hoist #1
Carykong
Gold Member
near Williamsburg ,Virginia
TC 35 New Holland and 52 Case VAC,LT25 Woodmizer logmill
Here is a picture of white oak extensions for my forks so I could raise the posts (7'x10'x12ft) by myself. Note chain hoist at the top so I can gently place the post on the footer gently and plumb.
/ oak extensions for chain hoist #2
Noce!
How are they attached?
I have the same tractor, any idea on how to set a 21ft pole into a 3 ft hole in the ground?
/ oak extensions for chain hoist #3
Noce! How are they attached? I have the same tractor, any idea on how to set a 21ft pole into a 3 ft hole in the ground?
You could do it with a fairly short boom pole. You just need to hook the pole a little higher than half way up. Here's my fork extender.
My oak extensions are boxed and simply slide over the existing steel forks
In order to lift a 20foot pole vertical you must attach. 11 to 12 ft up so the end going into your hole will hang down and nearly vertical
/ oak extensions for chain hoist #5
Did something similar several years ago using a RR tie. Broke the first one so we were more selective on the second.
JOHN DEERE R4023 SELF-PROPELLED SPRAYER (A64277)
JOHN DEERE R4023...
John Deere 720 Quick Attach Loader (A65640)
John Deere 720...
(4) Tractor Wheel Weights (A65640)
(4) Tractor Wheel...
2023 Schulte FX-318 Flex-wing Rotary Mower (A66285)
2023 Schulte...
2000 SHOP TANDEM AXLE TRANSPORT TRAILER (A65643)
2000 SHOP TANDEM...
Quick Attach Backing Plate (A65579)
Quick Attach...
