Gravel cost
/ Gravel cost #21
Uh....yea.
I think you meant to say something like gravel weighs more for a given volume than limestone.
I don't think you can get away with saying that a ton of gravel weighs more than a ton of limestone.
I am pretty sure a ton of gravel weighs exactly the same as a ton of gravel, as a ton of gold as a ton of feathers. :)
/ Gravel cost #22
Gold weighs more per ounce than limestone, (and less on a pound basis) but I didn't know gravel did.
No,, an ounce of gold and an ounce of limestone and an ounce of feathers all weigh exactly the same..
/ Gravel cost #23
Yea....issue of my finger typing something different than my brain was thinking.
A yard of gravel is about 3000#
A yard of limestone is 2700#
So you get more volume per ton.
So as an example....let's say you need a 500' driveway, 10' wide, 1' thick. That's 185 yards of material.
That would require 250 yds of limestone....or 280 yards of gravel.
If gravel is $13/ton and limestone $16/ton....that makes limestone 23% more expensive per ton.
But the job as a whole....would be $4000 for limestone or $3640 for gravel. Making limestone only 10% more expensive.
In other words......that $13 ton of gravel is equal to $14.30 worth of limestone. Which makes limestone a little more enticing than comparing by weight at $13 and $16
/ Gravel cost #24
Moss you and I are in the same County. WHere do I get this map?
I was given a book by a friend of mine that is a forester. He's the one that reforested our property. Very handy.
Today, its all on line.
First, go here:
Web Soil Survey - Home
Click the big, green START WSS button.
On the Area Of Interest tab (AOI), find your piece of property.
On the toolbar you'll see two AOI buttons. Ones for making a rectangle, the other is for making a polygon. Choose one of those buttons and draw a box or polygon around your property.
Once you've defined your Area Of Interest, click the tab at the top labeled SOIL MAP and there you go! It should show all the soil types in your AOI.
For example, I'm sure you're familiar with this local area.... :laughing:
489959d1480553545-gravel-cost-studebaker-png
/ Gravel cost #25
Then there'll be a legend to the left describing the soil types in your AOI like this...
attachment.php
/ Gravel cost #26
I will say, though, that this electronic map does not match my old book. While the defined areas are very similar, the soil types for my property in the book are tyner, fox (the one with the gravel), and adrian muck, while this electronic map shows mine as coloma, oshtemo, gilford, tracy, and antung. The book told me the fox area would have gravel right under it, and it did. This electronic version says the gravel will be at least 48" down, and its more like just below the topsoil.
Anyhow..... its still a great resource for anyone in the country to use. If in doubt, dig a test hole. :)
/ Gravel cost #27
Now a really cool feature of that website is you can go to the shopping cart and generate a custom soil report for free, and when you check out, download it for free. Its a really nice looking report. :thumbsup:
/ Gravel cost #28
Is this for similar size materials, sandstone and limestone typically have similar density?
/ Gravel cost #29
Yes. Comparing 57 to 57 or 8 to 8 or any other uniform washed stone.
Crusher run in either would be prooortiomally heavier, as the fines dill the voids
/ Gravel cost #30
No, an ounce of gold is measured in troy ounces, which equals 31.1034768 grams (1.097142857143 oz.), but there are 12 troy ounces per troy pound, (373.24 g) rather than the 16 ounces per pound (453.59 g). A "regular" ounce weighs 28.3495 grams and there are 16 per pound.
/edit Troy weight - Wikipedia
/ Gravel cost #31
OK, you got me there... but an avoirdupois once of gold and an avoirdupois (regular) ounce of styrofoam beads would weigh the same as well as a troy ounce of gold and a troy ounce of styrofoam beads would weight the same. That was my point in reference to what LD1 said.
I didn't see your point about weighing gold using the troy system.. But I do now, and I stand corrected. :)
/ Gravel cost #32
How much does it cost to cover 1/2 mile road in gold gravel?
:devil:
/ Gravel cost #33
last loads of gravel we got, they asked if we wanted black or gray 3/4-, black to look better next to asphalt, about $325 delivered for 10 yard load.. and yes, it weighs more per yard after rain...
/ Gravel cost #34
About $300 for 15 tons of crusher run...$200 for 5 ton 57's :eek:
/ Gravel cost #36
Crusher run is what it sounds like. Throw big rocks in crusher,result is crusher run. Depending on large screen size typically about one inch diameter down to powder. Screen size will determine maximum size
57 is screened gravel that fits between the #5 and the #7 screen. Gravel will be between one to one and a half inch in diameter. Screening gravel cost money and leaves less desirable end products
/ Gravel cost #37
A yard of gravel & a yard of limestone will weigh different but will cover the same area.
A cubic yard is 3'x3'x3' just like a pound is a pound.
In your example if it takes 185 yds to cover it will take 185 yds of gravel or 185 yds of limestone.
/ Gravel cost #38
What exactly is crusher run? Why is it so much cheaper than 57's? And while I'm asking questions, define 57's.
Crusher run is as it comes out of the crusher, dust to the largest size specified. When you buy a specific size, like 6, or 57, it should all be that size without any dust, ie clean washed stone, hence, more costly.
Gravel is stone not crushed.
/ Gravel cost #39
Crusher run and 57's were described accurately...crusher run will pack tightly together- great for driveways...57's were for backfilling a retaining wall- no fines to restrict drainage.
/ Gravel cost #40
Dont know what the actual screen opening sizes are....but never heard 57's described as 1"-1.5" stuff. Always heard it described as 3/4" - 1" stuff.......and thats actually what you get around here.
#4's would be closer to 1-1/2" stuff...(golfball sized). People arent normally using that for top-coat.
#8's is also commonly called pea gravel.....because the size is about like peas. 3/8"-1/2" or so. ITs also the size they use in asphalt mix.
