MF135 Petrol Engine problems
/ MF135 Petrol Engine problems #1
OzMF135
WELLINGTON East, South Australia
MF135 Petrol
I bought an old 1967 MF135 at the beginning of this year (2016)
It is a 4 cyl petrol engine.
Whilst it is very well worn, it ran quite well for 7 or 8 months.
It had oil and filters changed. New plugs, points, condenser, distributor cap & leads, rotor arm.
I have fitted a new ROP, new exhaust muffler.
For no apparent reason, the engine has developed a heavy backfire.
So I thought it required the timing rechecked etc.
so, here is where my problems begin......
Looking for the flywheel access hole to locate the TDC marks etc.... There is no inspection hole.
I'm advised that it should be on the left side of the tractor engine (when viewed sat on it)
Just below the starter motor on the bell housing.... !!!
There is nothing there.
Any help please ?
Also, I took off the zenith 28G carburettor and have checked it over and cleared all jets out and renewed the gaskets etc....
But underneath the carb body there is a hole into the bottom of the throttle chamber from atmosphere.
Obviously this is sucking extra air into the throttle chamber as well as from the air cleaner etc....
Can anyone help with their thoughts please...
/ MF135 Petrol Engine problems #2
Any help please ?
View attachment 489878View attachment 489879
Back firing can be caused by retarded timing ( either via improper initial timing, by worn distributor shaft bushings, failure of the centrifugal advance to function properly, etc) or by excessively lean fuel/air ratios ( leaking air downstream of the carb metering section via a leaky carb to manifold gasket, leaking head to manifold gasket, rusted or burned intake manifold, or misadjusted or clogged fuel metering jet).
What engine does your tractor have? Since you state it is a four cylinder, I presume it's a Continental Z series. What was the result of your timing check? Did you check the centrifugal advance mechanism ? The flywheel timing mark viewing port on the Continentals is below the starter assembly on the engine aft flange that the transmission bell housing bolts to.
"...underneath the carb body there is a hole into the bottom of the throttle chamber...." I believe the hole you are referring to is in the carb inlet where the choke is located and thus does not directly effect the carb fuel metering. It can however be a source of dirt. In some carbs, it is generally plugged with a piece of sintered metal and serves as a drain when the carb is "flooded " by over choking. I'm not familiar with the Zenith carbs so this is a guess on my part.
Hi Jerry/MT
I'm led to believe the engine is a continental. 4cyl petrol. What differentiates the 2 continental engines. How do I establish which model mine is ?
Timing marks appear to be non existent.
What workshop manual is best to acquire ?
/ MF135 Petrol Engine problems #4
Hi Jerry/MT
The two Continentals I am familiar with are the Z120 used on the Ferguson TO- and TE-20 (TE- uses Lucas electrics, TO- uses Delco electrics) the Z129 that's used on the Ferguson TO-30. I believe there is a Z134 used on the Ferguson TO-35 and I believe there is a Z145 used on the Ferguson 40.
Your engine should have a data plate on the left hand side in the middle (fore and aft) and right below the head to block split line. It maybe covered by paint and grime and that's the surest way to tell. If I were to guess, I'd guess it was a Z134. Differences include displacement ( the number after the Z is the nominal displacement in cubic inches) oil filter placement,compression ratios, valve sizes, system installations, etc.
The data a plate is your best way to know what you have.
Look on ebay for a OEM shop manual for your tractor. There will be a section on the engines in your MF135 in that manual. It's a good investment if your are going to work on your 135. You can also find one on Yesterday's Tractors web site. Make sure they are the OEM shop manuals and not the IT shop manuals. The IT are not detailed enough and do not cover all the tractor systems.
/ MF135 Petrol Engine problems #6
/ MF135 Petrol Engine problems #7
Also check your plug wires to make sure one has not failed or corroded. Hello Jerry. It's been a while.
/ MF135 Petrol Engine problems #9
yeah Kid. I've been pretty busy with other stuff this fall. Good to hear from you.
/ MF135 Petrol Engine problems #10
There should be a hole to view the timing mark on the flywheel on the lower left side behind your left foot when seated. It least that where it was on my Z145. You could always use the old school method to find TDC with number one cylinder when it reaches the top.
/ MF135 Petrol Engine problems #11
G'day Oz.
Threre were only two petrol engines widely used in the 135,s one was the continental z134 on the standard 135 ( No dash gauges) and the other engine was the z145 used in the deluxe model it had oil pressure ,ampmeter and tractormeter gauges plus a few other little things.
set points to 12 Thou ,bring number one cylinder to TDC then turn the engine back approx 3/4 inch on the outside edge of the front pulley this will give you 10 Degrees before top dead centre some tractors in australia had a timing "Notch" on the inside edge of the pulley( Nearest the engine) I have never seen a timing window on a petrol engine in australia.
I would replace the points and the condenser, Set the crankshaft as suggested ,with the cap of, loosen the distributor turn the ignition key to the ON and slowly rotate the distributor you will see and hear the spark indicating that the points are indeed at the critical open position ,you can do this as many times as you want just make sure you are not to near the coil or the cap ,you may get a little reminder.
The Hole on the bottom of the intake should have a sintered plug to allow any excess fuel to escape it will not affect the running but it will allow dust to enter the engine sugges you plug with silicone or your favourite hole filler!!
The most common cause of backfire with regard to the carburetor is the butterfly shaft it wears with age and can cause a weak or varying fuel mixture ,there is a service kit available it comes with two bushes and instructions ,you will have to drill out the carburetor body and fit the bushes and new shaft etc, this you will find the tractor runs like the proverbial Swiss Watch .
Note The year of Manufacture is stamped on an oval aluminium tag riveted to the distributor should be say 4/65 meaning 4 th month 1965 or whatever. over the years I have found that although this is a Lucas number the tractors were within a few months of the date stamped on the distributor.
ooroo.
Hutch.
Thanks so much for this information.
The tractor is 1967 vintage.... The distributor is stamped like u say.... 866
So that's about right - Aug 1966 ......
There is no timing marks to be found anywhere.... So will try your method ��
I have purchased and am waiting for a OEM workshop manual. That may guide me a little too.
Chris
Chris
So everyone.
Thank you so much for your help and suggestions.
Finally sorted.
Have removed distributor and found that in one of its previous lives, this item has been seriously abused.
Heavy plier scoring to the shaft. And although the advance and ****** springs were intact, they weren't from this tractor, nor identical. The centrifugal weights had been forced so much by a screwdriver or jemmy. They were barely able to move without fouling.
New distributor, immediately cured.
On a different note.
The actual engine appears by design to be a continental Z145 engine (as best I can determine)
There are no markings on the block that give any ideas.
There are no timing marks either on the crankshaft pulley &/or timing case.
There is definitely no viewing "hole" below the starter motor as should be expected.
I removed the starter motor and could obviously easily view the flywheel with its relevant markings.
On the starter motor hole edge on the flywheel casing there is a machined groove. I static timed it to this.
Then with the starter back installed. The engine started first time. Runs very well.
No easy way to time the engine ignition without the starter motor out.... .?? !!
Starter motor hole Marking, is clearly visible.
As is the timing marks on flywheel.
Does anyone else understand why this is so ?
/ MF135 Petrol Engine problems #15
G'day oz .
I did tell you how to time the engine WITHOUT removing the starter motor maybe you did not hear me!!!!!!!!!!!!
Hutch..
Hi Hutch
Apologies. I did try, but must have made a boob. It ran like a bag of poo.
After setting up with starter out, on a static of 6degs b4tdc. and it ran.
I then redid it with your method and it ran also........
So I did make an initial mistake. Thanks M8.
I did listen Hutch :thumbsup:
/ MF135 Petrol Engine problems #17
If there is a hand crank for that motor, you could crank it to start by hand. Just ****** the timing a tad (45 degrees) and have at it. DO NOT WRAP your thumb around the crank handle when trying this method.
I used to start my Farmall C this way even in the dead of winter.
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2020 Can-Am Defender Lone Star 4x4 Utility Cart (A64553)
2020 Can-Am...
2021 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2021 GMC Sierra...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
