mx842
- Joined
- Feb 26, 2011
- Messages
- 881
- Location
- Richmond Va
- Tractor
- Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
Exactly.
I have been checking the floor temp for a couple days now and the floor temp has risen to mostly 69 degrees all over, up from an average of 55 before. There are a couple cooler spots in places that I planned on not getting as warm like in my welding room and my parts room. The temps in those rooms are around 65 all over. They are both small rooms (10X10) in size that I didn't need to be real warm. The days have been mostly warm mid 50's in the day time and 30's to low 40's at nights with a couple nights in the 20's but it warmed up pretty fast come morning.
Where as there feels like a big difference between the water going into the floor and the water coming out the temp gauges are showing about 20 to 30 degrees difference between the two sets of manifolds. It's hard to see those little gauges with my poor old eyes but I think that's about right. I haven't been making really hot burns just keeping enough wood in there to keep the tank water around 140 degrees because I didn't want to load it heavy until I was sure both my pumps and controls were working and all my leaks were gone which at this point seems like all is good.
Also I have noticed that the stove doesn't seem to be making anywhere near the creosote it was before. I've only cleaned the stove pipe one time since I fired it off and there was just a small bit of paper like stuff in the section that connects to the schedule 40 stove pipe that goes through the wall. I have a section of lighter gauge stove pipe that connects to the schedule 40 and turns up about 10 feet. I need to extend this at least another 10 feet to get it above the main roof line of the building but didn't want to mess with that until I got everything else all straightened out. I've been looking for a schedule 40, 4 way slip fit connector to make up the whole stove pipe and chimney system. That way I can add 20 ft of pipe to get over the ridge line and have a port hole to rake the stove pipe and to rod the chimney pipe and have another section below the 4 way with a clean out door sitting on a concrete pier to hold the weight of the whole structure. I'll probably have a couple guy wires attached to the corners of the building to help support it also just to be safe. That pipe is pretty heavy and I wouldn't want it to fall over on some thing or some one that happens by.
