7010 Tie Rod Ends
/ 7010 Tie Rod Ends #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
2013 7010, tie rod ends worn out, 800 hrs. Anyone else see this? Little package is coming today,$ 800-900. I'm trying so hard to like this tractor.
/ 7010 Tie Rod Ends #2
Sorry to hear this. LS should have made the tie rods ends with grease fittings. I noticed that mine doesn't have fittings either. Sad to say but the automotive industry has gone the same way. You've got me thinking. Maybe there is a way I can drill, tap, and add grease fittings to mine.
/ 7010 Tie Rod Ends
Good idea, hopefully the replacements will have fittings, actually I have to replace the tie rod end, and the short shaft that ends in a joint that's attached to the steering cylinder, that joint has even more play than the tie rod end, I could see them moving back and forth as I drove.
/ 7010 Tie Rod Ends #4
I just went outside and looked at mine and no fittings either. I have 450 hours and no discernible play. Is there a condition or scenario that contributes or accelerates wear such as running/turning in FWD on pavement? Do you have R1 or R4 tires? Thanks!
/ 7010 Tie Rod Ends
Did quite a bit of road driving, all in the winter which should be more forgiving. Seems a lot of wear for ( to me ) a new tractor. My 91 Kubota with 4x the hours did much more and has never been touched, but no doubt plowing snow and travelling has taken it's toll. It just kills me to buy parts for a "new" piece of equipment.
/ 7010 Tie Rod Ends #6
At least you could get yours. I broke the tie rod tube on my xg 3025. It is back ordered from Korea. I was able to repair it.
/ 7010 Tie Rod Ends #7
Is this the same tractor that had the front hub failures or am I thinking of someone else? I think the ends could be drilled and tapped. Wonder on the metal shavings.
/ 7010 Tie Rod Ends
This is the tractor that's had the hub replacements, but all this present wear are on parts external to the hub, no contact with shavings.
/ 7010 Tie Rod Ends #9
I have a 2014 with 300 hrs. Haven't noticed any slack in the tie rods... I have noticed that they are sealed though.
CT
/ 7010 Tie Rod Ends #10
LS mechanics replaced both hubs today on my 2012 7010. They are replacing all of them under warranty. Mine were fine but nice to get the latest upgrade done. I have close to 900 hours on the tractor. The tie-rod ends the mechanics had with them today had grease fittings. I am going to drill mine to help extend their life.
/ 7010 Tie Rod Ends #11
Today I added grease fittings to my tie-rod ends on the 7010. I thought it would be better to give them some grease before they fail. Just a note, that the boots should be sprayed periodically so they don't dry out and crack allowing water to get in.
John Deere 348 Square Baler (A65579)
John Deere 348...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2017 Freightliner M2 106 TMA Attenuator Truck (A64194)
2017 Freightliner...
Hydraulic Auger Mini Skid Steer Attachment (A64553)
Hydraulic Auger...
Landhonor 3-Ton 3-Bag Air Jack (A66408)
Landhonor 3-Ton...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
