JD 175 Farm Loader
/ JD 175 Farm Loader #1
JoshB
Member
Spartanburg
JD 2155
I have a 175 loader on my 2155. I bent a rigid hydraulic line yesterday while moving some debris around, which resulted in a hole and a nasty leak. Item #13 seems to be obsolete.
Does anyone know of an alternate PN to AW22254 (other than AW26073)? I might just have to have a line manufactured but I figured it's worth asking.
Thanks!
- Josh
/ JD 175 Farm Loader #2
Picture I have is a bit different but same part #. Looks to be obsolete like you said. I'll check one more source for you and see if we get an answer.
Here is a picture of the line that is damaged.
It is the middle line (behind the one in front) which got bent and twisted by a branch on the right (left on tractor). The twist made a hole under the hose wrap.
/ JD 175 Farm Loader #8
Yea it's obsolete unfortunately. It will be fine if you get a regular hose made for you. Don't need to go back with hard line.
Ok great. That was going to be my next question. I'll just find a flex line and replace it with that.
Thanks for chiming in!
Would your software be able to tell you what the thread size is on the fitting (#17 on the diagram)?
The flex line will probably come with male/male ends. I'll probably have to pickup some unions to make it all work. Maybe remove the fitting from the regulator (#19) and flex hose straight into that, but then will still need a union to connect to the other flex hose (#16).
Would those be 3/4" fittings?
/ JD 175 Farm Loader #12
I'll check once I get back in. I'm testing a tractor right now. Ill get back to you in a second buddy
/ JD 175 Farm Loader #14
Josh
Have you considered welding or brazing your old line? Back when I was employed by a JD dealer I've seen many hyd lines repaired by brazing.
The people I bought it from painted green over everything. Under the paint is a good bit of rust. That line is pretty used up. But thank you for the suggestion!
/ JD 175 Farm Loader #16
Are these the spec's you need?
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
Andersen Fifth Wheel Hitch (A65579)
Andersen Fifth...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
