Ball hitch for tractor.
/ Ball hitch for tractor. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I know this question has been asked a million times but what is the cheapest way to hook a ball hitch to a tractor. I have a new 19' flatbed trailer that takes up a bay in my tractor shed. Sometimes I need to get it out/ put it back (tight fit) and doing it with the truck is a pain, especially when I'm alone. I see the three point deals but assume they will go upward since the three point hitch arms are not fixed in place.
Drawbar between the three point hitch arms would have the same problem.
I'm assuming that using the fixed draw bar would be cheap, but not sure if the trailer tongue would allow good mobility that close in behind the tractor.
I've seem hitches that attach to the bucket. Seems that would be touchy to maneuver.
Interested in what you guys use. Thanks.
/ Ball hitch for tractor. #2
This or some variation of it. Mine will fit my QH on the Kubota or hitch to the 3pt on the Ford.
/ Ball hitch for tractor. #3
I built this one for moving trailers around. All my trailers have a lot of tongue weight so I don't worry about the 3 pt. arms lifting. Made mine from a used draw bar between the lift arms, angle steel, used Reese type receiver, some square tubing. Basically just stuff I had laying around the shop.
/ Ball hitch for tractor. #4
I use a stationary hitch receiver on my BX "drawbar," with a HF extension to raise a ball insert and move it back.
Dual Hitch Extender
Bruce
/ Ball hitch for tractor. #5
I have a hitch receiver welded to the top of my bucket. It is touchy but works good. I also use a ball on the drawbar. And, I welded a receiver to my Farmi winch. That's the best place to hook a trailer because it is further back. What implement is usually on your machine? Maybe weld a hitch on it?
/ Ball hitch for tractor. #6
The coolest part about these is ease of use. Right behind that is versatility. Look at George's and mine. We have accessories welded to them to use on multiple tasks.
For the OP, he describes a situation of moving a dollied down trailer in/out of a building. Perfect setup for these hitches. Forget the trailer jack. Simply pick up the trailer hitch with the 3pt and move.
I placed a large ball on top of the tower of mine so I can move my GN. I've pulled my GN several miles hauling pipe using this setup.
When splitting a trailer load of wood I use it to spot my trailer mounted splitter and/or the trailer. Hitch/unhitch and never leave the tractor seat.
/ Ball hitch for tractor. #7
I welded a receiver to my small BB and used to use it a lot until I built my 3pt hitch.
I've read a good many people having issues with the three point moving upward. You guys haven't had this issue at all? My trailer is also heavy....I can't pick up the tongue when it is sitting level. I don't weld but you can find the triangular hitches for the 3 point for about $50 so that may be the way to go. I guess you could also run a small chain from the bottom of one of these to the drawbar mount to keep the lift arms from floating.
Dual Hitch Extender
Bruce
I'm thinking about this approach. Simple and cheap. Are you able to turn tightly with the trailer on?
/ Ball hitch for tractor. #10
Yes, it puts the ball behind the tires and lift arms, and my two small trailers have straight tongues, so I can turn 90 degrees plus when I need to.
I'm not just moving the trailer a bit, but I'm towing it around for work. A hitch on the lift arms would probably be more convenient for just moving the trailer a short distance.
Bruce
/ Ball hitch for tractor. #11
I have no idea how many times I've used my hitch to move trailers of all sizes shapes and descriptions. I've never had my 3pt lift. If backing a heavy load such as my 28+4 GN tandem axle tandem wheel trailer with 4 ton of material on it I make sure to keep my 3pt low.
I suggest you purchase and use whatever type you feel you can control.
/ Ball hitch for tractor. #12
I bought a cheap under bumper receiver at Harbor Freight for $20. I then flipped it upside down and mounted it to the top of my FEL bucket. I then use about a 8"drop and it's a snap. Just drive in, pick it up, and go. It's very maneuverable and great visibility.
/ Ball hitch for tractor. #13
No upward movement at all. I have 3 trailers I move from time to time. The lightest has about 500# of tongue weight, the heaviest tongue is about 1200#. I do the same as Richard, back up, lift and move, drop trailer without getting off the seat. I do have a grab hook, clevis and a pipe to store the hitch when not in use. The hitch fits my HF quick hitch or any 3 pt. tractor. You can easily add a safety chain if you are worried about the trailer tongue being too light and lifting.
/ Ball hitch for tractor. #14
I would put it on the loader. I have a contraption that slips over my pallet forks and we use it to move trailers all the time. Works great and is really easy to put the trailer where I want it as I am going forward.
We have about six trailers and at least one or more of them gets moved weekly this way from the single axle bumper pull to my 32' tandem dual gooseneck and even my 53' semi trailer.
/ Ball hitch for tractor. #15
I have never done it but I have been thinking about it, grabbing a cutting torch and cutting a hole in one of my pallet forks. When I bought mine a few old farmers were talking about it, cut a hole, add a ball and move around trailers.
/ Ball hitch for tractor. #16
I use this, homemade.
/ Ball hitch for tractor. #17
I just googled it, wow there's a few diff ways to use pallet forks to move trailers.
/ Ball hitch for tractor. #18
I would not recommend it. I did this and while it worked the heavy tongue loads on some trailers bent that fork with the ball in it down slightly. Not a lot but it is maybe 1" lower than the other fork. Makes it a pain when trying to pick up things with the forks as they are no longer even.
Just weld something up out of channel that slips over both forks and has a ball in the middle. I built mine from scrap in less than an hour.
/ Ball hitch for tractor. #19
I have a 3ph one. No issues here either.
Most trailers have enough tongue weight it's a non issue. Only cause for concern would be breaking while going down hill. I can see that causing the hitch to raise. Other than that....no issue. When just moving trailers around, I also never get off the seat. No need to couple or raise the jack if just moving them around the yard.
/ Ball hitch for tractor. #20
I'm not sure what you mean by the 3PH going upward? Do you mean since the 3PH floats if you put weight on the trailer the 3PH will go up? If I use a tractor to load or unload a trailer I chains the trailer mover to the drawbar.
You can see the key hole on the back of the trailer mover in this pic.
[URL=http://s278.photobucket.com/user/NHRAx1320/media/Trailer/20150831_180901_zpsswel5tvm.jpg.html]
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
HUDSON BROTHERS DBL AXLE TRAILER (A63291)
HUDSON BROTHERS...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
GRAVITY BOX (A63291)
