2013 Terex PT110 Forestry
/ 2013 Terex PT110 Forestry #42
I have a PT 110 and I just want to know why the air conditioning not working while under load. Any solutions?
/ 2013 Terex PT110 Forestry #43
Did you find the problem with the A/C unit while under load? Im having the same issue with mine right now.
/ 2013 Terex PT110 Forestry #44
Why, when I hook a CAT BR166 Brush Cutter that is 5.3 -21.1 gpm into the machine, the A/C units starts to blow hot air into the cabin. Any suggestions?
/ 2013 Terex PT110 Forestry #47
Anybody had any issues with this hose?I have blown two in the last 18 months,Seems the hose straightens under pressure putting pressure on the steel elbow.The pipe always goes on the seam on the elbow.$1k nzd from the dealer for the terex part.
/ 2013 Terex PT110 Forestry #48
Usual response I am the only one with a problem from the dealer.I have cut the pipe off tig welded a fitting to the block and run all hose.
You're not the only one. I'm on my third.
/ 2013 Terex PT110 Forestry #50
Mate, you probably get a better response on www.heavyequipmentforum.com . There's plenty of owners, operators and fixers there.
How long is the ASV parts warranty?
/ 2013 Terex PT110 Forestry #51
Now I am getting paranoid. I have to go look and determine where that is for certain and start monitoring it. What were the symptoms when it blew?
The other forum is good but there are not very many Terex PT 110 owners posting over there from what I have found. We seem to be in the minority.
/ 2013 Terex PT110 Forestry #52
Symptoms -Mine is noticeable if the loader arms are raised overnight and they settle, there is a leak somewhere.Other than that a smell of hydraulic oil or leaking underneath.They changed the design of the hose so i guess they knew they had a problem or changed supplier I will see if i still have a pic of old and new and what I have done to run all rubber hose last week if that helps.
/ 2013 Terex PT110 Forestry #53
old and new design
/ 2013 Terex PT110 Forestry #54
will see if this outlasts the genuine overpriced part
/ 2013 Terex PT110 Forestry #55
Earlier you posted that you tig'ed a fitting to the block and I was confused.
It appears from the photo that you used the flange from the original piece and tig'ed a fitting to the flange and then mounted that back to the unit.
Is that correct?
Nice job. Are those JIC fittings?
Any issue with heat in the area on the hose. I did some hydraulic tube bending several years ago and then brazing ORFS fittings on the tubes for a project when I was nervous about hoses in a high heat area.
2000 Hino (A64194)
2000 Hino (A64194)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2021 CATERPILLAR 302.7D CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
2022 EZ-GO ELITE...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
