Enjoying the new grapple
/ Enjoying the new grapple #1
desh
Member
Pensacola, FL
Kubota L4701 HST 4X4
Just thought I would post a few photos and my experience so far with the new Landpride SGC1072 grapple on my Kubota L4701. It has taken me about 2 hours to clean up two large debris piles on my property--something that would have probably taken me a couple of days if doing it by hand. One caution when dumping debris in a trailer. The bouncing motion of the front end loader can cause the tractor to connect with the trailer fenders if too close and not careful...something I found out the hard way. :( Otherwise, this is a great attachment that I will get a lot of use out of.
/ Enjoying the new grapple #2
Very nice. I have no need of one for my current land, but if I did, I'd buy one in a heart beat just because they look cool and fun to operate. :D
Thanks! My favorite part of the grapple is clamping down on on stuff with the claw. You can hear the hydraulics crushing and breaking planks, wood, limbs, etc. :thumbsup:
/ Enjoying the new grapple #4
Welcome to TBN and Congrats on the nice new grapple. Don't you just love being able to grab stuff and move it w/o getting off the tractor :thumbsup:
gg
/ Enjoying the new grapple #5
Grapples are the most fun you can have ...on a tractor.:) Another member on this forum says that grapples will make a lazy man out of you. There might be some truth to that.:D
Grapples are a heck of a lot of fun and also save the back a lot of aches/pains. The grapple is a very close second to the bush hog in the usefulness category.
/ Enjoying the new grapple #7
When I bought mine, having never owned one, I went back and forth deciding between the 'closed bottom'/bucket type and the one you have. I ended up with the bucket type. It's better for some stuff, not as good for large brush piles.
One of the many cool things about a grapple is being able to pick up really big stuff. Like stumps. When we cut down a big tree, instead of cutting the tree down to firewood length in the middle of the yard and making a mess, I cut the tree to 80 inch lengths. Then move those pieces to where I'll be splitting wood. The larger pieces get cut down there and then split -- it saves a ton of time moving the wood. The grapple picks up the big pieces easily, as well as that last big chunk near the bottom of the tree that's useless.
One piece of advice -- if you haven't moved heavy stuff: If you are going down a gravel grade, the tractor will 'rock' a little from the weight up front. The rocking motion can lift the rear tires up for a second with each rocking motion, which means you lose traction, which means you slide down the hill.
Don't ask me how I know.
/ Enjoying the new grapple #8
When I bought mine, having never owned one, I went back and forth deciding between the 'closed bottom'/bucket type and the one you have. I ended up with the bucket type. It's better for some stuff, not as good for large brush piles. One of the many cool things about a grapple is being able to pick up really big stuff. Like stumps. When we cut down a big tree, instead of cutting the tree down to firewood length in the middle of the yard and making a mess, I cut the tree to 80 inch lengths. Then move those pieces to where I'll be splitting wood. The larger pieces get cut down there and then split -- it saves a ton of time moving the wood. The grapple picks up the big pieces easily, as well as that last big chunk near the bottom of the tree that's useless. One piece of advice -- if you haven't moved heavy stuff: If you are going down a gravel grade, the tractor will 'rock' a little from the weight up front. The rocking motion can lift the rear tires up for a second with each rocking motion, which means you lose traction, which means you slide down the hill. Don't ask me how I know.
I was helping the neighbor transporting logs and slid by him going down a hill. He still laughs about that....
/ Enjoying the new grapple #9
I have the same grapple. It's been a work saver and as you have, I've bounced it of my trailer fender. 👍
/ Enjoying the new grapple #10
Go down a hill on wet grass and see what happens!! :eek::shocked: I to learned to always keep something heavy on the back (boxblade/tiller) and stay in 4wd going down hills. :cool2:
/ Enjoying the new grapple #11
Yes, that taught me a lesson in keeping it in 4wd. :)
/ Enjoying the new grapple #12
When I slid on the gravel, I had it in 4WD AND I had a really heavy blade on the back. . .
Kind of panicked (tree coming up fast!) so I hit the button to release the grapple. Did the trick, but the tractor bounced like a roller coaster.
/ Enjoying the new grapple #13
Had you hit the brakes or just released/let off the go pedal? HST or geared? Very unusual for an HST to start sliding with just releasing/letting off the pedal which is just one reason I'm an HST ONLY guy.
/ Enjoying the new grapple #14
HST. I was lightly on the pedal, although I can't say that once I started sliding I didn't panic and hit the brake briefly. (This was a while ago). I think what happened is that as I came down the hill, perhaps moving a bit too fast (I was probably in "Low Range/Rabbit") the tractor started a see-saw motion with the heavy weight on the front and the back making it pivot in the middle. So each time the front end dropped, the rear wheels came off the ground for an instant, and vice versa. I've felt that rocking motion other times as well, although now I'm more aware when it might happen and haven't had a repeat.
/ Enjoying the new grapple #15
desh,
Can you tell me how much the Landpride SGC1072 weights? I looked on the Landpride web site, but I didn't see anything about weight.
desh,
414 pounds according to my paperwork. Seems very strong, but not too heavy. Perfect size for my LA 765 loader.
/ Enjoying the new grapple #17
How about price. Reading this thread because I'm seeing a grapple in my future :D:cool2: and since I buy thru Kubota dealer (Barlows) it will probably be a Landpride. Currently have a Landpride HD25 hydraulic post hole digger on order and expect next to be the grapple.
/ Enjoying the new grapple #18
If you have work for it to do, you will wonder why you waited so long to get one.:thumbsup:
It was about $3.5K total including grapple, the third function, complete installation, and tax. The third function was about $1K of the $3.5K.
/ Enjoying the new grapple #20
:eek::shocked: First, I have very little use for one but that has never stopped me before.:D I already have the hydraulics installed on the front of my B2650 for my front backhoe. Second I was thinking Barlows told me around $1500 which I am preparing for. Guess I need to nail him down on specific model. I remember he talked about Landpride open bottom with clamping top vs bottom being bucket style. He has always given me pretty fair deals and I think usually about the same prices to everyone. Guess that's why he sells so much all over the country. Any way, I'll get specifics when my post hole digger arrives and I pick it up which should be about any day.
