driving down steep incline in gear
/ driving down steep incline in gear #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
It is bad for a tractors clutch or tranny to drive down a steep incline while in gear, clutch not engaged (clutch pedal not pushed in) so the only thing that slows down tractor is speed of gear. I always thought that was the correct way to go down hill....Alternative would be in neutral with brakes applied.
/ driving down steep incline in gear #2
No, that's the way to do it. No issue for the clutch if you are in low gear. Generally speaking, if you find you have picked a gear too low, better to stick with it rather then changing.
Of course 4wd engaged is best if you have it. It give you 4 wheel brakes. The lousy 2 wheel brakes on tractors have killed many people.
/ driving down steep incline in gear #3
Just FYI ... The clutch is engaged until you push the pedal in. It is disengaged when you push it in. Going down a hill with the clutch disengaged is likely to explode the clutch plate due to overspeed. Be careful of any coasting [disengaged] situation faster than the transmission gear will go. This is deceptively easy in a low gear.
Yes, that is what I meant and you are correct, clutch would be engaged going downhill.... That's what I thought, just wanted to make sure.
/ driving down steep incline in gear #5
Clutch engaged. 4wd engaged. Brakes as needed. In low gear with a 4wd tractor you should be able to manage even steep grades with good control. The impulse when you start to go too fast is to disengage the clutch and push on the brakes which is pretty much what you do in a car. This will usually result in the tractor speeding up and less control. When you do this you find out how much better engine braking works than the brakes themselves!
/ driving down steep incline in gear #6
Some of the stuff I see on here never ceases to amaze me.
/ driving down steep incline in gear #8
I hear you, but...
A person don't know what they don't know. Give credit for asking. We all come from different backgrounds (most Americans drive automatics), so things that seem obvious to you and me, to another person....well, a person don't know what they don't know.
....but should they be able to figure it out on their own? That's a more complicated question.
/ driving down steep incline in gear #9
The thing is that for the most part TBN is inhabited by people who have and use their tractors as hobbies or peripheral to their actual day jobs. Not true for every member but there are a lot of us here for whom this is true, including me. I have close friends who are farmers. They are either driving or working on a tractor all day every day. They have never heard of TBN.
I came to TBN, 10+ years ago, to learn about tractors. What to buy, what implements, how to use it, how to fix it, etc. And what made TBN so attractive was the friendly, helpful and accurate advice I got. That's what makes it so great now too. I've now got ten years of experience on my tractor using it for many jobs with many implements. I've also spent a good bit of time on my B-I-L's farm machinery. And I still ask some stupid questions here on TBN. And I get good answers. Always.
/ driving down steep incline in gear #10
So wierd to see this question today. Yesterday I was driving my hst equipped tractor across the sloped hill. As I started to turn around at one end, my leg must have knocked the shift lever into neutral, I did not have the 4wd engaged.
Brakes locked up immediately leaving an 80 foot skid mark in the mud. Blew through a brand new steel gate and picked up speed heading for a 15 foot drop off with a pond at the bottom. Was able to maneuver tractor head on into a large fir tree. Luckily, I had the fel on, and it absorbed most of the impact.
No damage other than frayed nerves. Never again will I operate on that hill without being in 4wd, also looking for a way to lock shift lever in place so it can't be nudged out of gear.
Hills are always a factor here, muddy hills are 10 times worse. Lesson learned, won't be forgotten any time soon.
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
17501-FL (A56857)
17501-FL (A56857)
2005 Ford Excursion (A60352)
2005 Ford...
