BX2360 front snowblower - how to keep it from digging in?
/ BX2360 front snowblower - how to keep it from digging in? #21
That pipe thing sounds interesting
/ BX2360 front snowblower - how to keep it from digging in? #22
If you do this use schedule 80 pipe. I used schedule 40 and it lasted 3 yr. I had a piece of schedule 40 left so I am using it again this year to make a new one but when that one is gone it will be schedule 80. My bucket is about worn out as I do a lot of road maintenance on a 1 mile long gravel road and when I get a new bucket I will be cutting 1 foot off each end of the old bucket and welding a plate to those pieces so I can bolt them to the ends of the new bucket to make an approx. 6' wide bucket for snow. The tractor will easily handle this and clean up will be 50% faster. Can't wait.
/ BX2360 front snowblower - how to keep it from digging in? #24
I had a similar problem with my rear mount Pronovost Puma on my BX22 so I modified the standard skid shoes...see pic
/ BX2360 front snowblower - how to keep it from digging in? #26
Awesome thanks!
/ BX2360 front snowblower - how to keep it from digging in? #27
Bellweather
Nice work! I made mine out of UHMW because I had some left from another project. Were I to do it again I would go with steel as you did.
/ BX2360 front snowblower - how to keep it from digging in? #28
Bellweather
How long have you had the uhmw ones amd how are they wearing? I considered steel but I really wanted to shape them rounded on all edges so i could turn a bit with the blower down.
/ BX2360 front snowblower - how to keep it from digging in? #29
UHMW is incredible material. We used it for water bearings in hydro units weighing tons. I normally do a lot of snow blowing and the first set I made lasted 5 years. They would have lasted longer but I was making a set for a friend so I made a new set for me at the same time. I also wanted to shape the edges but in the end I don't think that was as important as I thought it was. Steel would never wear out soooo...
/ BX2360 front snowblower - how to keep it from digging in? #30
UHMW is incredible material. We used it for water bearings in hydro units weighing tons. I normally do a lot of snow blowing and the first set I made lasted 5 years. They would have lasted longer but I was making a set for a friend so I made a new set for me at the same time. I also wanted to shape the edges but in the end I don't think that was as important as I thought it was. Steel would never wear out soooo...[/QUOTEW
What thickness of the UHMW did you use?
44052 (A55852)
44052 (A55852)
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
MASSEY FERGUSON DL250 FRONT LOADER (A59823)
MASSEY FERGUSON...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
