EddieWalker
Epic Contributor
Your smart getting it all done now. Seems that when I get most of a project done, I tend to wonder off to another project, and then three years pass and it's all overgrown on me with weeds.
I find the shovel work to be some of the hardest. Lots of twisting of my lower back under load. Moving the cement wore us out....but there is something about shovel work that just beats me up.
All your work and expense in building could go for naught if a heavy hurricane comes along and causes an overflow of the dam breast. I visualize an erosion that would wipe out the road should the pipes get blocked by debris from such a storm.
Putting in a bridge over the original crevice (ravine) might have been less consuming and practical in the long run.
JMO PA-GUY
I'm hoping to get clover and some moss established. I will have to buy new rolls of landscape blanket since my thief took all of mine.It's coming along nicely. How are you going to smooth out the dirt so you can mow there?
My land is separated by a serious ravine upstream of the pond and stream and marsh below the pond. The engineer designed the bridge to handle the "100 yr storm". Will it work? I do not know, but I have done everything I can to insure it is built properly. The engineer's original plans didn't call for a cement headwall. It was designed for soil at a 1 in 3 pitch. When I told him I was going to use a stack wall he said that would make it even stronger. I have had lots of questions from people about why I don't just build on the other side of the pond. My wife was one of them. My answer is simple. Because I want to build on the far side of the pond. At the top of the hill. If I build closer to the road, I would have a beautiful view. But it wouldn't be what I want. And I would spend the rest of my life living a quarter mile from the spot I want to wake up every morning. With the view I want. And the sunsets I want and the feeling of privacy that I want just out of my reach...because I didn't have the courage to build a bridge for fear that a storm might wash it away.All your work and expense in building could go for naught if a heavy hurricane comes along and causes an overflow of the dam breast. I visualize an erosion that would wipe out the road should the pipes get blocked by debris from such a storm. Putting in a bridge over the original crevice (ravine) might have been less consuming and practical in the long run. JMO PA-GUY
The last few post made me question if it should be called a bridge? Should it? Land Bridge? Levy? Just pondering.
I'm looking forward to it also. I wish I had been able to start the bridge earlier because I am not likely to be able to get my foundation done till spring.All your work looks great. I know many areas of our country have lots of water so land owners have ponds and small lakes. Yours looks awesome. I am always jealous when I see that much water. Looking forward to the house build.
