Backhoe hand throttle not working
/ hand throttle not working #1
samr12
LAUREL,MS
NT204C
hello,
I have a nortrack nt204c and the hand throttle does not rev engine, when moving it, feels like it does have some tension, looked at diagram in manual but cant figure whats moved,broken or missing?
thanks sam
/ hand throttle not working #2
It sounds like the rack is stuck or the governor has issues. How is the oil level in the fuel injection pump?
will have to get the manual out to see how to check the inctector pump oil and get back to you thanks bob.
didn't know but going to mention that accelerator pedal work fine
thanks sam
/ hand throttle not working #5
thanks sam
They should both connect to the same place. Sounds like a broken linkage.
With the engine off, push the pedal and look at what moves. Then move the hand throttle and see what moves and what doesn't.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
New/Unused 12 Ton Hydraulic Jack (A65583)
New/Unused 12 Ton...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
