LONGER GREASE GUN HOSE
/ LONGER GREASE GUN HOSE #1
prs
Logan, WV
JD 650, Ventrac 4500Z AJ02248
DeWalt makes a super powered rechargeable battery powered grease gun, 10,000# max pressure! Oh, oh, oh, oh, oh! ;-)
But that is overkill and it comes with a hefty price tag. The main feature I notice that could help those of us with the 4500 is the 42" hose. Now, that would get us in there with slack to spare to reach the two universal joints (well, the rear one is easy anyway) and to contort around the front tires to reach the front lift pivots and to reach forward from the left side to get the front zerk on the steering cylinder end joint. There are similar ones sold, but this one seems to be better built and longer. So I went to the DeWalt site to find the part number DCGG703-42. The description even suggests it will fit most grease guns as a replacement. DeWalt even provided local and online vendors such as some Lowe's and Amazon. It is still a little pricey, $32.50 including delivery two days with Prime, but I took the bait and ordered. I will follow-up when I get it to report if it fits any or all of my lever or pistol grip grease guns and if it is as well made as it looks. I have a service interval coming up again soon.
prs
/ LONGER GREASE GUN HOSE #3
I think someone said they made up a long one with hydraulic hose, don't remember him mentioning what it cost.
/ LONGER GREASE GUN HOSE #4
I've made a longer one from short ones plus a 1/4 inch couplings.
Bruce
/ LONGER GREASE GUN HOSE #5
Oh, duh. I thought you were referring to the battery operated grease gun for $32.50. I caught up now. It was late when I read that.
/ LONGER GREASE GUN HOSE #8
Now you need to put a LockNLube coupler on that long hose: http://www.tractorbynet.com/forums/oil-fuel-lubricants/304889-locknlube-cupler-grease-gun.html
I put a hose on my lever gun, works great, lock the coupler on, then use both hands on the grease gun. :thumbsup:
/ LONGER GREASE GUN HOSE #9
I just got one of those for my expensive DeWalt grease gun referred to here. It really is the ticket. Pricey for what it is but well worth if for what it does.
/ LONGER GREASE GUN HOSE #10
I would have to have a separate gun for my backhoe if I used the lock n lube. I can barely fit a standard nipple between the backhoe swing pinions. My farmers co-op had one that was the same length as a standard hose nipple but pricey at IIRC $35. I seem to recall it being made in Canada but now I cant remember the name. I guess the next time I go there, I will bite the bullet and lets some of the moths out of my wallet.
/ LONGER GREASE GUN HOSE #11
I have the same problem with my hoe. I've considered adding something to wrap those zerks around to make them more accessible. Some grease whips maybe. Although they say they are only good for use on hand grease guns. Maybe some rigid tubing of some sort. It always try to remember to grease them with the backhoe sitting on the dolly so they get a good dose.
/ LONGER GREASE GUN HOSE #12
You don't need separate gun, just buy a 1/8 inch NPT zerk and screw it into the old coupler that you are using now. Lock onto it with the LockNLube and hold it into those places.
I made an extender from the pipe that I removed from the lever gun:
/ LONGER GREASE GUN HOSE #13
Front universal on the Ventrac... I grease it with a hose threaded through the hydraulic hoses, just like the manual says... EXCEPT....
To get the hose on the fitting I grab it with a pair of pliers and push it on...
How to do I get the pliers on? I do it when I change the oil and grease it with the oil filter off so I can get my big fat hands in there........
Mark
The lock on coupler looks great and generally gets high reviews, but on the Ventrac the hand space to get a coupler onto the zerk for the front drive shaft universal is so very limited that I am not sure I could operate the thumb lever.
There is one on my contour mower deck that barely clears for coupling with the smallest diameter zerk coupler I could find and even at that it is tilted. Sometimes smaller is better.
prs
The DeWalt long hose and coupler came in today, but its fitting is slightly larger than any of the three guns I have. So, I can shop for a conversion fitting or re-tap the the opening in one of the guns.
prs
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
IH International 1466 Tractor (A66285)
IH International...
