3-Point Hitch 3-point Hydraulic cylinder has flow by
   / 3-point Hydraulic cylinder has flow by #31
The closed lockout valve under the seat will not hold the lift arms with load when the engine is shut off. I also notice some hydraulic fluid tends to leak under one of the end caps where the lift arm attaches to the shaft.
Mine did this as well until recent ( I think I fixed it). There is just an O ring under those lift arms, and that fluid is not under pressure there it just splashes up and is just in that compartment (as described by HOye and which I knew there was no pressure on those) . Its more to seal out water entry than anything. But its just like a $0.75 O ring that is behind that cover plate on the outside. When you buy parts get 2 of those and take that bolt of the end of the arm and pull the arm off to get the old oring out or dig it out with a pick and put it all back on there including the washer on the shaft and put your oring in there and put the cap and bolt back on. Once you know what your doing it can be done in less than 10 mins a side.
And from your description yes your cylinder O ring is shot.
   / 3-point Hydraulic cylinder has flow by #32
Check chains are run from the lower pin on the implement to the upper pin on the top link. Once adjusted, the implement is held by the chains, not the hydraulics. Another good thing with them is that if you have to lift the implement, then all you have to do is just drop the lift and it will go back down the limit of the chains, no need to adjust height up and down again.
Some people call them limiter chains.]
Here is a PDF on how to make your own
http://www.ntractorclub.com/howtos/pdfs/Limiter-Chains.pdf
Here is a set for sale
Chain Limiter Kit
This still makes no sense to me? How can this hold the implement up? the top link is lifted with the arms as a unit attached to the implement, so attaching chains to the lift pins to the top link, doesn't that still mean the 3pt is supporting the weight? Im just trying to understand this hear and wrap my brain around it.
   / 3-point Hydraulic cylinder has flow by #33
Ok I opened the link on how to make them and see that its attached to the tractor top link mount not the upper or outside end of the Top link on the implement side.
Don't know that this will help. Picture of an FX24D. Second picture showing where the housing bolts down.
Were you able to replace the gasket between the housing and transmission or reuse the old one ?
   / 3-point Hydraulic cylinder has flow by #35
I doubt it! If the one he was working on was like mine (mine Is a VN recon and they use some paper gasket and crazy strong glue. I have to take a wire wheel to clean it off. THey put it on every gasket!!!
I would not reuse a gasket unless its rubber and in good shape for this, you don't want a leak and have to redo it. That said I used silicone (ultra grey) to seal mine up. Just clean your surfaces up well and use like brake clean or some solvent to clean oils off the mating surfaces and put a thin layer on both surfaces and really you snug the bolts hand tight let it sit for an hour then torque them down then wait 24 hours before you use it or put oil in it. Most people skip this process and I use to and usually it doesn't matter but you can see why it works better this way. For this application you can fill with oil basically right after since it sits above the oil line but if you want to stick to the 24 hour rule just done run it till the next day.
I use silicone on pretty much any one of the gaskets I take off my tractor. If you careful and esp if you wife the gasket mating area you don't get the amateur silicone splooge everywhere the surfaces meet like most idiots leave.
   / 3-point Hydraulic cylinder has flow by #36
Pretty sure I replaced it but it has been awhile. If it doesn't tear up it would be fiie to reuse, maybe a little sealant on it. You can buy sheet gasket material at any auto parts store and cut one out using a ball peen hammer. Ever done that? Gasket Material for Cars, Trucks & SUVs
   / 3-point Hydraulic cylinder has flow by #37
that's an awful lot of work when a silicone will work.
If your buying stuff from hoye and can get one for a few dollars I might do it, but I would use silicone way before I bought sheet gasket and beat one out of it. MOst folks have no idea what or how to do this now a days.
   / 3-point Hydraulic cylinder has flow by #38
I have a roll of gasket paper here but it's not my favourite past time cutting gaskets out of it, only if really required :confused2:
After replacing the piston seal ring on the hydraulic lift, the lift arms raise. but don't lower. The position of the end cap on the left lift arm controls some type of valve (pic below). Is this a pressure relief control ? Could the position setting of this control be the problem ?
   / 3-point Hydraulic cylinder has flow by #40
I don't think it controls a relief valve but really don't know what it does. Any reason to believe it is in a different position now then before? If not, doesn't seem reasonable that would be your problem. Do you have weight on your 3 point? Is the stop valve open?
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2020 JOHN DEERE 317G SKID STEER (A52707)
2020 JOHN DEERE...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2015 DRAGON  130BBL VACUUM TRAILER (A55745)
2015 DRAGON...
