KL6010 - uneven loader arms
/ KL6010 - uneven loader arms #1
DieselBound
Elite Member
Arlington, WA
Kubota B7800; Kioti NX5510HC
In order to get more visibility with this issue -I have it noted in my thread about my tractor- I figured I'd start up a separate thread as I've heard from one other person having this same issue., and felt that others may want to look out for this issue.
As you can see in this picture, the loader arms set lower on the right side of the tractor. This is of my newly delivered NX5510CH with KL6010 loader:
The bucket is not resting on anything, nor is there anything in it. Even after sitting over night there is no change. When the tractor was loaded on to the truck (to return to the dealer's) I was able to watch the bucket lower on to the deck (I have very little in the way of a flat surface to check against), and the right side of the bucket clearly touched down what appeared to be a good 2" before the left side (loader was starting to push the tractor up a bit before the left side of the bucket touched the deck).
The tractor is back to the dealer's for this and a couple of other issues. They have another KL6010 that they have available for testing with.
/ KL6010 - uneven loader arms #2
Have you checked and verified all the tire pressures?
I wish it were that easy:(
The bucket edge should be parallel with the top edge of the brush guard. A low tire wouldn't change the relative distances between the bucket edge and the brush guard.
I actually measured from both sides of the torque tube to the brush guard and found those distances to differ by approximately 1/2". There's so much geometry happening with these arms that I stopped measuring there: figure I've identified that there is an issue and that now it's up to Kioti to figure out where things are off. I suppose that it's even possible that the mounts on the tractor frame itself could be the issue (or a combination).
/ KL6010 - uneven loader arms #4
Nope those measurements wouldn't be changed by tire pressure. It would change the levelness (is that a word?) of the bucket.
Sounds like youve got some other issues. I did hear about someone else, different manu that the FEL mounts were not equal by a few mm and it threw the whole geometry off. End result was they replaced his tractor as it was a manufacturing flaw.
/ KL6010 - uneven loader arms #5
I would be the other feller having the KL6010 on a NX6010 with an obvious droop to the right. You can see by the pics it's blatant. I did some measuring and took a pic of one measurment that didn't require two hands. The pic angles ain't the greatest but the right side measured 1/4" more than the left. The measurement was taken at the frontside of the bucket roll pin where there's reinforcement. There were other measurments that were different from each side also. At top lift with bucket rolled down there's a 1 1/2" difference from lip to ground. I have spoke to the dealership and he's contacting Kioti IRT this situation.
/ KL6010 - uneven loader arms #6
Wow, those are obviously off! No denying that. That would make me crazy on a brand new tractor. Should have never made it out the dealers door for delivery to a paying customer. Looking forward to hearing how this is resolved.
Tractor is back from the dealer's. New loader. Original was welded incorrectly (off by 1 1/2"?). So, first big test on the responsiveness for resolving this issue and I'll have to give high marks.
Anyone else finding that their loader arms are also askew should get a hold of their dealer ASAP and get a replacement loader.
Here's how things now look from the cockpit:
/ KL6010 - uneven loader arms #8
This must be a common problem. Hopefully it is a small batch of bad loaders.
Sorry your new tractor story had to start with this. Hope it's all smooth sailing from now on!!!!
ovrszd, I don't think that it's very common (looked all over the Internet and the only other out-of-whack KL6010 that I found was bgruss75's). So, yes, I think that it's going to be traced back to just a handful of loaders: recent ones it appears.
Ha ha, "smooth sailing." With the amount of rain that's been coming down here I would have been wiser to have bought a boat!:laughing:
/ KL6010 - uneven loader arms #10
Yep, you guys have been getting hammered!!!
Glad your dealer fixed your problem with little drama!!!!
/ KL6010 - uneven loader arms #11
Do you think this issue pertains just to the KL6010 loaders? Reason I ask is because I've noticed my loader arms uneven on my CK2510(KL2510)
seems like one side of the bucket hit before the other side on even pavement. I've also noticed a popping noise from the right loader arm, did anyone notice that on theres?
Anything manufactured can be subject to some sort of misstep. I'd think that the processes of construction would be similar in their loaders.
Check with your dealer. First, however, I'd look to take some quick measurements to see if you could spot what would be an obvious build issue (rules out twisted loader arms due to [ab]use). Might look to start up a separate thread just like I did, hoping to attract the attention of others with KL2510 loaders: post pictures; scan the Internet and look for pictures that others have that might indicate a similar issue. Do make a note here referencing that thread: I'd like to follow it. And if you do find that it's a manufacturing defect this thread might help add some weight to the notion that Kioti needs to do a bit more QA on their loaders.
/ KL6010 - uneven loader arms #13
Is there a serial number on the loader tag? That may be a way to indicate if there is a certain range of the problematic loaders. Mine is in the shop currently or I would look at mine.
Yes, there are serial number plates on these loaders. I didn't note what my original loader's serial number, I wish that I had. However, how this all works is that under warranty work everything has to be documented, which most certainly, I'd think, means that Kioti is noting what serial numbers are being affected here. I'm going to see if my purchase documentation has it listed: if it does then I'd like to find out whether the dealer has the new loader's serial number properly registered.
/ KL6010 - uneven loader arms #15
Sorry I didn't mean to hijack this thread. I havent thought about it much till I read this thread, but I will definitely look into and take some measurments. Thanks
/ KL6010 - uneven loader arms #16
Glad to hear all your issues were resolved. Well, I've talked to the dealer and he's brought it up with his service manager. Waiting on what they're plan of action will be. With the uneven loader I can't back drag a pile dirt evenly. Not to mention it bugs my OCD not having it run parallel to the brush guard line.
No, no problem. Just thought that for better visibility (to catch others with similar model) to start up a thread on it (people may not be searching, so seeing the topic pop up might catch their eye).
I can totally relate to the OCD comment!
No doubts as to whether Kioti will get you straightened out (ugh, pun!). Post updates.
/ KL6010 - uneven loader arms #19
Glad they got you fixed up, looks perfect.
/ KL6010 - uneven loader arms #20
Took some pics and measurements today, it appears mine is 1/4" lower on the right side. I'll probably start a new thread in reference to ck2510 owners but wanted to post here first. Do y'all think that is enough difference to contact my dealer and try and get resolved? I'm like others , OCD lol
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40XXMJ464379 (A65563)
2021 Kenworth T880...
New 43X16-20 NHS tire on 6-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 43X16-20 NHS...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
