Flailer/Mower Ford 918H
/ Flailer/Mower Ford 918H #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
Gear box keeps loosening in spite of lock-washers and or red thread loc. All the heavy duty tines are in place and the flailer appears balanced but there is tremendous vibration.
Anything I am not doing ???
/ Flailer/Mower Ford 918H #2
If it's vibrating badly, something is unbalanced or bent & those vibrations are causing things to come loose. Have you checked to see if the rotor it self got bent at some point. Generally that totals the impliment as the are over $1k + shipping to replace.
/ Flailer/Mower Ford 918H #3
Yep, something is bent if all parts are in place and properly functioning. It doesn't take much. Mine has 33 knives and if I lose one I immediately know it.
/ Flailer/Mower Ford 918H #4
Bent rotor, bent driveshaft, universal joint failing you definitely have a turning part failing
/ Flailer/Mower Ford 918H #5
My 917 is current hanging from my loader. Rotor is back in, but just sitting there with no bearings. Waiting for paint to dry & a trip to Home Depot to get some carage bolts (PO put some normal bolts in & I hate trying to get a wrench on em). My rotor has a lot of dings in it, but ran ok until the driven side bearing blew.
Apparently I forgot to grab a photo of the dinged rotor. It was mostly on the bars welded on to mount the knives too.
/ Flailer/Mower Ford 918H #6
You forgot to get pics of the entire project?? :)
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
Aproximately 72' of Steel Catwalk (A62679)
Aproximately 72'...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
2022 Deere 17G (A64126)
2022 Deere 17G...
John Deere 925 Cultamulcher (A66408)
John Deere 925...
