L4701 vs L3301
/ L4701 vs L3301 #1
cobalt650
Member
Waunakee, WI
Kubota MX5200
Gents,
I went shopping for an L3301. But I found that the L4701 actually may be within reach. More power, more substantial tires, ability to handle a 72' vs 60' loader/box scraper/shredder---it seems like it is worth it to figure out a way to make the $7-8,000 leap. Any thoughts? Thanks much:)
/ L4701 vs L3301 #2
Love my 4701.
I got one new for $23,750 OTD. The 3301 wasn't much less.
/ L4701 vs L3301 #3
Weight defines what a tractor will do. Bigger is better if you can support the logistics (towing, if needed) & can deal with the decreased manuverability.
My L3200 (almost exactly the same as the L3301) pulls a 72" box blade ok, a 4000 series would pull it better though.
I'm happy with my L3200, but looking to replace it with a cabbed grand. Debating between an underpowered L3560, or the slightly bigger L4060 or L4760. I like the 3000 series for manuverability, but the 4000s will do a bit more work with the extra weight.
/ L4701 vs L3301 #4
Gents,
I went through the same decision process recently. For what I would be doing, I concluded the 4701 would do it all easier, faster, and safer. The 3301 or 3901 would get it done, however I didn't want to have regrets or be considering trading up in a couple of years. The only advantage of the 3301/3901 is the more compact size if you have really tight spaces or need a lighter tractor. But looking at the specs between those models and the 4701, the width/length and turning radius are pretty close leading me to conclude that the 4701 is the perfect middle ground--still compact, but with a lot more power, stability, and capability. Also, look at the upgrades that come standard on the 4701--telescoping 3 point, dual brakes on left side, cruise control, upgraded HST transmission. Those were significant in my purchasing decision. The 0% Kubota financing kept the larger Kubota within reach for me. I see it as a long term investment. No regrets here.
/ L4701 vs L3301
Awesome summary Desh, thank you! I have a five year old 60" King Cutter shredder, I could save a bit of money just getting the loader and box scraper with the L4701, but a new 72" shredder sure would be nice!
/ L4701 vs L3301 #6
It's nice on the budget using an existing 5' cutter, but my new Landpride 6' cutter sure helps the work get done a lot faster! I feel 6' is the perfect size for the 4701. Good luck with your decision.
/ L4701 vs L3301 #7
I priced out an L4600 (predecessor to the 4701). The MX that I bought was actually cheaper. It's got a hair more HP, a little bigger frame, and a stronger loader. Just something to consider.
/ L4701 vs L3301 #9
Just going to say check out an MX series. Way more tractor. I have both, so I can tell you from experience. L3301 is a great smaller tractor, but the MX is a beast.
WACKER NEUSON LTN6L LIGHT PLANT/ GENERATOR (A65056)
WACKER NEUSON...
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
CAT 953C 4-in-1 Bucket (A68134)
CAT 953C 4-in-1...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
