Finally got the new grapple mounted...
/ Finally got the new grapple mounted... #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
I have the T-8 QA swapped over, mounted and plumbed in. (Still need to run the PTO hoses up onto the loader arms.) I went to the hydraulics store in Knoxville this morning and stocked up on the needed Faster male hose connections. Based on a great suggestion here, I set the Aux/QA circuit up with two females, which will stay clean because something is always plugged in, and am putting two males on each attachment. Two attachments down, so far, one more with a hydraulic cylinder (snow/dirt blade) yet to go...
So, here's the obligatory pictures of the EA 50" Wicked Grapple on the PT-1430.
I think this 50" wide Compact size, with its 30" jaw opening is a good fit for this size machine even if this one has about a 60" track.
The mounting angle of the QA plate appears to be fine. I can put both the bottom jaws and top lid firmly on ground to press down on green, springy brush to compress it, so I'll be able to get the biggest bite. It will actually tilt just a bit further, so this is not at full tilt travel -- which is a plus. I have a strong curl upward from here. The factory hoses are about 6" - 8" too long for MY machine (my quick connects are farther down the arms, in front of the roll-over bar, not behind it, like on my old PT-425). I'll have to figure out where's the best place to put a loop to take up the slack in each of the hoses, yet keep them away from all these moving parts.
It has plenty of upward curl for moving brush. I don't think this is curled full up, but I honestly don't recall. EDIT: Looking at the position of the curl/tilt cylinder, there's still considerable "curl up" that could be used.
I really didn't work with it, but I had to go grab a bite of brush off the burn pile, because... well just because that's what it does...
No strain, no mess, no fuss! I think it's going to be a great addition to the tool kit....
/ Finally got the new grapple mounted... #2
Just looking at that jaw-full of brush makes me drool! :laughing:
/ Finally got the new grapple mounted... #3
That looks awesome.
Moss, with your work in the woods harvesting locust and such, IMO you REALLY need one. For example if you'll look at the three arched, serrated webs between the "fangs" on the lid, those are designed to clamp and grab a tree trunk from the end, so you can drag it out of the woods, without having to hook up a chain, cable, etc.
484188d1476143673-finally-got-new-grapple-mounted-29616244333_821bfe55a1_k-1-jpg
/ Finally got the new grapple mounted... #7
Very nice! Do they sell them with T8 attachment plates or did you have it added? I'm getting along just fine with the grapple bucket you sold me, but I'm always adding to the "wish list"!
I sent them the plate and they added it. BUT, I think they used it as a pattern and can now make their own T-8 plates.
/ Finally got the new grapple mounted... #9
KentT,
What is the clearance between your tires and the chassis. Do the chains rub on the chassis?
/ Finally got the new grapple mounted... #10
My only concern is the weight of the attachment VS what I pull out of the woods. With only 800# to play with (at the QA plate), some of those telephone-pole sized trees can get the old PT Pucker going pretty quick with just my logging tongs.
But for brush and branches, I think it would be interesting.
KentT,
Just about 2 inches. The chains do not rub.
/ Finally got the new grapple mounted... #12
Better buy some paint for that grapple. Like a lot of paint. You're gonna need it.
That LED light bar is gonna burn it right off!
???? Not sure what you're getting at.
/ Finally got the new grapple mounted... #14
I think he means your light bar is GIGANTIC!!! :laughing:
Sure, its LED and won't melt the paint on your grapple.... but its GIGANTIC!!! :laughing:
What can I say? It fits the opening under the ROPS, matches the alternator output (no battery discharge while using it), and didn't take up needed/usable space. It likey won't be used much, but when I need light, there's plenty of it...
/ Finally got the new grapple mounted... #16
See? It wasn't that bad of a joke!
/ Finally got the new grapple mounted... #17
Where did you get it? How much (not sure I want the answer to that one!)?
Thanks, and oh: nice grapple!
Thanks! I found it on eBay, at what I thought was a good price:
CREE 28'' 180W LED Light Bar Spot Flood Beam UTE SUV ATV Boat Driving Work Lamp
Item price $39.97
Quantity 1
Item number 262138582744
Shipping service UPS Ground
Looks like that low price must've been a mistake on the seller's part, or they're really price-gouging now, because the same item is listed at $92-plus...
BTW, 180w may seem like a load on the electrical system, but consider that 4 of the factory sealed beams (I had two more mounted under the ROPS on my PT-425) draw 220 watts (4 x 55ea) and put out only a small fraction of the light this thing does.
/ Finally got the new grapple mounted... #20
Item price $39.97
Quantity 1
I can smell the paint burning from here.
And I can't even smell.......
[that was a joke in case you missed it]
Looking up the paint burner on Amazon as we speak, thanks.
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59910)
2013 ISUZU NQR 4X2...
COMBINE SCREEN (A63745)
COMBINE SCREEN...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
Case 586H 4wd Off road forklift (A63118)
Case 586H 4wd Off...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
PALLET OF PICKER BARS, GAUGE WHEELS (A63745)
PALLET OF PICKER...
