L4740 HST Engine knock
/ L4740 HST Engine knock #1
Husaberger
CA
L4740 HST, DK65S
Was just about to do some trenching when engine started to knock
Tractor has about 250 hours with routine service
Kubota knock - YouTube
All informed opinions welcome
/ L4740 HST Engine knock #2
Sounds like a complete misfire on one cylinder. Either an injector or delivery valve. Loosen the nut on the top of each injector one at a time. The one that is dead will be the one with no change in the sound of the engine.
Thanks Kuboman
What do you suggest once I isolate the faulty cylinder?
/ L4740 HST Engine knock #4
Thanks Kuboman
Injection systems are usually very reliable and usually fail because of contaminated fuel. Make sure your fuel is clear of dirt and water. Once you determine which cylinder is dead you can pull that injector and have it tested/repaired or you can switch it with a different cylinder to confirm it is an injector or it may be the delivery valve.
makes sense
will try that tonight and post results
thank you!
/ L4740 HST Engine knock #6
I hope you guys are right.
Sounds like a spun rod bearing to me.
Ok. Performed the test suggested by Kuboman
Cracked each injector open and each one altered engine performance/revs dropped (some more than others) :(
As an aside, I removed the valve cover breather hose to get at the injectors. Is there supposed to be this much smoke coming out of the vent? Kubota knock 3 - YouTube
Not much smoke coming out of the exhaust Kubota knock 2 - YouTube
Aside 2. Fuel filter looked dirtier than I ever remember seeing it
It was changed in January
Opinions?
Recommendations?
/ L4740 HST Engine knock #9
That #3 video proves to me it's not just an injector. Looks like a ton of blow-by so I would go with rings and/or a broken piston. What does the air filter look like? I ask because the tractor looks pretty dusty/dirty. The engine could also be "sanded" from a dirty air stream. All in all, definitely not good symptoms for such a low hour engine.
SimS
/ L4740 HST Engine knock #10
Definitely more than just an injector. That is a lot of blowby. Is there any muck on the inside of valve cover?
You have serious issues no doubt.
FORREST CITY 4R RIPPER BEDDER, 3PT (A63290)
FORREST CITY 4R...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
40ft Six Section Heavy Duty Metal Storage Shelf (A64047)
40ft Six Section...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
