Buying Advice need to upgrade
/ need to upgrade #21
I just think the front might be a little light...
It was, good call. That's why I made a bracket to double up on the weights. :thumbsup: Still handles like a sports car with the loader off though. :cool:
/ need to upgrade #22
When I was looking for a cab tractor, I found that most manufacturers cab models start around the 35-37 HP size. Mahindra does have a cab version of the eMax25, but it's not heated or air conditioned, and not the increased power you want. Based on most posts here on the subject, I doubt you'd be disappointed with a slight step up in HP. We went with the LS. But, Kubota, MF, and NH all have nice cab models as well. There also seems to be a lot of love for Kioti here (I've not experienced one yet). They all have a little different feel and layout. Try as many as you can to find the one right for you.
/ need to upgrade #23
You doubled the weight from what is in the picture?! I'd love to see what that looks like.
I know what you mean about taking the loader off and feeling like the tractor is suddenly articulated.
/ need to upgrade #24
No, the picture is with the weights doubled up from what the factory offers. I also added a couple of rear wheel weights. :rolleyes:
But back to the OP. Again, to get the size that I felt you were asking about, I'm pretty sure that Kubota is it as far as an all factory setup. Step up another frame size and you have quite a few different options. ;)
/ need to upgrade #25
Cool. Thanks for the pictures. Surely it's not light in the front now! :drink: (sorry for the tangent)
/ need to upgrade
Thanks for that....i am finding the same thing.... JD does not use a factory cab till the 3033 model...alot of $$$$ i dont want an aftermarket cab..
/ need to upgrade
i will check this model out...thanks alot
/ need to upgrade #29
TYM has a cab for the T234. That has a 24 hp Mitsubishi in it. Loader max at pins is over 1300lbs.
/ need to upgrade
ok, i will check this out...thanks alot
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
Massey Ferguson 9250 (A63118)
Massey Ferguson...
SAMSUNG ESPOKE REFRIGERATOR/FREEZER (A62131)
SAMSUNG ESPOKE...
(2) 16.9R30 TIRES & WHEELS (A62131)
(2) 16.9R30 TIRES...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2018 Ford F-150 Pickup Truck (A61568)
2018 Ford F-150...
