BX80 Series Announced!
/ BX80 Series Announced! #1
nikerret
Kansas
Kubota BX25D-1
Kubota Introduces All New BX8 Series Subcompact Tractors | TractorByNet.com – Compact Tractor Portal
First, they follow the next number in the series, from 70 to 80, but screw up and replace he BX25 with the BX25D, then the BX25D-1, now the BX23S. What was wrong with BX26?
It looks like some really cool features will give the JD 1-series a run for the money. 80 series has a tilt steering wheel, storage compartment, removal of the FEL without getting off the tractor, and a new "four point" quick attach system. If it's the skid steer quick attach, like pictured in one of Everything Attachments' recent posts, that will destroy the competition. It also has new pins that won't leak excess grease and some other neat options.
Of course, as a ten month owner of a BX25D-1, I am wondering if I should have waited another year and a half, to get the new model. But then, I don't want a new model, I want them to get the kinks out. Perhaps, I will wear mine out, in the next year and be looking at the "upgraded" model 80 series.....:laughing:
If Kubota keeps the good things about the 70 series, I think it will be an easy choice over the JD. When I was shopping, I had them neck and neck, at the end. The JD 1-series really trumps the BX70 series in ergonomics and features. However, I found the Kubota hydraulics better, even if not as strongly rated, on paper.
/ BX80 Series Announced! #2
Oh gosh and the BX2D is one I was considering- does this mean they'll really be cutting deals on the now? Haha- wishful thinking!
/ BX80 Series Announced! #3
Sounds like a few very nice feature improvements.
/ BX80 Series Announced! #4
The loader has changed from an LA243 to an LA340 or LA344. If this is the usual KG capacity, that is a major loader lift upgrade. See photo below.
Bruce
/ BX80 Series Announced! #6
The loader has changed from an LA243 to an LA340 or LA344. If this is the usual KG capacity, that is a major loader lift upgrade. See photo below. Bruce <img src="http://www.tractorbynet.com/forums/files/kubota-buying-pricing/484026-bx80-series-announced-0816_bx23e_transport_1013-jpg"/>
It can't be kilograms unless they were BSing us before. 243 x 2.2 is only 534.6 lbs., whereas the specs say 745 lbs.
(Later: that figure may actually apply to the "500 mm forward" specs, which are listed as 518 lbs.)
/ BX80 Series Announced! #7
The improvements are welcome and overdue, time will tell if it's enough to keep up with the competition.
/ BX80 Series Announced! #8
Curious to see if this BX series will stop when the go pedal is released like all former Kubota HSTs and all other Kubotas other than BX 70 series or if it will coast on till it finally stops or the brake is engaged. If so, would that be an admission of wrong? The abrupt stop in reverse on the 50 series BXs was never acknowledged but the 60 series came out pretty quick and the issue went away in that series.
/ BX80 Series Announced! #9
Interesting to see 3 different versions of seats in the picture of the 3 models. I have never really liked the seat on my BX2360 and I had hoped that the seat from the B2301/2601 would be used in the new BX80..... but apparently it won't be.
/ BX80 Series Announced! #10
The '23S' has the same seat because of the swivel mechanism. The BX1880 has the current BX seat, the BX2380 and BX2680 do get an upgrade.
super excited for these new models. Kubota is FINALLY making really significant changes and adding some really significant features that in my mind make someone finally consider trading their old BX's on the new model.
/ BX80 Series Announced! #11
I like what I see. Any idea when more details and pictures will be released by Kubota? I still have a few questions that were not answered by the original article. I think I see a relocated loader joystick, my main complaint. Any other big improvements left out or glossed over in the article?
/ BX80 Series Announced! #12
If you look at the last photo in the article the loader joystick is definitely moved. I just picked up my new 2370 on Wednesday too :( lol.
/ BX80 Series Announced! #13
As a BX owner with a front hitch and snowblower, I want to know what the new 4pt front lift is!
/ BX80 Series Announced! #14
I'm willing to bet the 4pt is nothing more than two solid pins on the top, and two QD pins on the bottom. An operator can hook up to a front implement, lift it to engage, and lock the other pins.
/ BX80 Series Announced! #15
I just bought my BX2670 this summer. While I have the drive over MMM, I'd really like the Swif-Tach loader with one-lever couplings. While I could see me getting a new BX in a year or two, the fact that my QA, forks, and front blade wouldn't match up to the new 2-lever QA will be a deal-breaker for me.
/ BX80 Series Announced! #16
Is there a new qa coupler for the loader? I read it as the new 4pt qa they referred to was the front hitch for the frame, not the loader.
/ BX80 Series Announced! #17
Love the loader control position. Need to understand the 3rd function up front better. If it's already piped in and ready, I may have to trade in my BX-2370!
Still trying to understand how you can take off the loader without leaving the seat. Where is the stand then?
/ BX80 Series Announced! #18
If you put down the stand before getting in the seat....
Bruce
/ BX80 Series Announced! #20
Even the John Deere 1025R requires you dismount to unhook the hoses, will be interesting to see.
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
