/windmill water pump
/ /windmill water pump #1
muddstopper
western NC
Ventrac, Steiner
BIL called me up a little while ago to discuss building a windmill water pump to keep his stock tanks full of water. He had mentioned this project about a year ago and has already built the windmill. He used 8 plastic 55 gal drums cut in half with the halves stacked on top of each other and bolted together for vanes. He put the 8 vanes on a 8ft dia cable reel. Using 1in rod for a vertical shaft. Now he is wanting to build a piston type water pump out of PVC. This is where things start getting iffy. Mostly because the windmill is vertical instead of horizonal and I dont think the 1in shaft material is going to hold up well supporting a 8ft dia x about 6ft tall wind mill. To cap it off the windmill is about 20ft above and 150ft from the pond he wants to pump water out of. Also, he is wanting to run 1/2in pex tubing from the pump to the pond. He has alread aquired the pext tubing. I have looked at several pvc pump designs on utube and think I can pretty much build the pump as they aint that complicated. My question is whether or not the pex tubing will work as the suction side of the pump. My first thoughts are that the pex is made to hold pressure, but I am afraid it will collaspe as a suction line. With 20ft of head, it is going to take about 9 lb of vacuum just to pull the water up to the pump. My second concern is the 1/2in tubing being to small . He's not trying to pump large amounts of water. Not sure what I am getting into, plan on checking things out one day next week. Until then, I need a few opinions and suggestions on how to proceed.
/ /windmill water pump #2
What size PVC pump will you be building? Any pump with 150' of 1/2'' pex (.485 ID) suction line and 20' lift will result in very low volume pump. Most pumps are rated at a 10' lift and as lift increase water volume goes down. What will the strokes per min of the pump be? Do you have pictures of the windmill?
/ /windmill water pump #4
The pex should hold up against the vacuum, but it's awful small.
As a rule pumps are better at pushing than pulling the fluid. If it's possible to put the windmill close to the pond and then run the 1/2" pex as the outlet and have a 1-1/2" inlet it will probably work better.
When pulling with a pump loss of prime is always a problem. The close the pump is to the source the better!
I havent seen the windmill yet as I just learnt yesterday that he had it built. According to BIL, its working and hard to hold by hand, so I assume it has a little torque to it. As for flow, the pump will be used to fill a stock tank with overflow returning to pond. High flows shouldnt be needed. As for the size of the pvc pump. thinking about using 2in sch 80 pvc with 1 1/2 sch 80 pvc as the plunger. Using sch 80 pipe there is only about .040 difference between the inside dia of the 2in pipe and the outside dia of the 1 1/2 in pipe. Video I watched showed the builder cutting groves in the 1 1/2in pipe to accept orings to make the seal between the two pipes. I dont know how long such a setup would last, but it aint like rebuilding or making a spare would break the bank. The one in the video didnt show what kind of pipe was used as the suction or pressure lines, but he used 3/4in pvc check valves and I would guess 3/4 pvc for both connections. I hope we can get this thing to work because I am thinking about building myself one to use in a heating and AC project I have been wanting to build for a long time. Thats a differentt topic I will start another thread for when the time comes.
Have you seen any specs as to what kind of vacuum the pex tubing can handle, I spent a good portion of last nite searching the web and never found anything to suggest the pex would or wouldnt hold up to vacuum. As for placing the windmill close to the water source, I agree 100%, but also knowing the site, the pond is sort of down in a hole between two hills and not sure it would get the wind it needs to actually work. At any rate, he has already built and installed the windmill so I guess we will just have to try it where it is at and see how it goes. Also, he already has the pex tubing, its blue in color if that means anything, And when I mentioned the possibility of the pex not being able to withstand the vacuum he said no problem, he would just switch it out for pvc. I believe that even if the pex does collaspe from vacuum, it would show that the pump system has the power to pump the water to where he wants it. So it looks like a little trial and error is going to be needed.
/ /windmill water pump #7
I understand bil bought the pex already but it can be returned if needed. I understands it's cheap for length you can get since you need close to 200 feet off pipe but i don't think 1/2 inch it's big enough even for low volume. I worked with Pex and I'm pretty sure that it won't collapse since its cold water . I think you may want to upgrade size off pipe since its a low volume flow out will have .51 friction loss per 100 feet. Yours is double that so priming is going to be difficult for you. Just doubling the size of pipe to 1 inch will be under less then half for 200 feet friction loss so friction won't be a problem .
/ /windmill water pump #8
I think I would get a bucket or something and pump out of it near the windmill as a test. A lot of unknowns in this project so that might break it down into manageable problems.
/ /windmill water pump #9
Furrball idea #1:
Use the mill to drive a piston/reed valve compressor.
Run air from the compressor, thru the pex, to a 2nd, pneumatically driven water pump, down at the pond, to push the water uphill to his stock tank.
Lossy, to be sure, but avoids collapsing tube trauma, loss of prime paroxysms and the heartbreak of cavitation by maintaining positive pressure in all the plumbing.​
Furrball idea #2:
Put a capstan on the mill and drive a pump at the pond with a capstan on it, using a loop of rope.
Simpler build. 'Course you'd have to keep everyone clear of the rigging so they don't get fouled and go for a Nantucket sleigh ride with an unhappy ending.​
Furrball idea #3:
Move the tower to the pond and raise it enough to catch the wind.
Just tossing them out there to see if the cat licks it up.
Or the dog brings it back.
Running them up the flagpole to see if anyone salutes.
Man, do I love applejack!
-Jim​
/ /windmill water pump #10
Some other options would have the windmill generating power with a small electric pump at the pond. Or, go back to early oil patch days where pumps were operated by a cable system from a central power source. That might be an easy way to go.
Jerk line system:
/ /windmill water pump #11
My experience with windmills tells me that you should lift water with a submerged pump and use a large check valve to be able to lower the piston quickly. So, converting your vertical power shaft to a water lifting mechanism is do-able with the right transmission. I would have recommended a more conventional cyclic powerhead using, say a small gas engine shortblock or compressor body as a secondary option to pump air to an air motor water pump at the pond or better, just use a conventional water pumping windmill system. Livestock need a reliable water supply at all times.
The main consideration is what volume of water does it take (say in a given day or week) to supply the number of animals expected. That sizes the machinery along with how much wind do you have over the course of time. No problem with too much water, but not enough is a bad situation.
A conventional, 'vintage' windmill with an 8' wheel is good for about 1-1/2 hp in a strong wind, but has time on its side as far as pumping water volume. I have 8 of them on my property. Minimum 2" cylinder with a 4" stroke and a tank right at the pump jack works best for me. maybe a 30% - 40% duty cycle on the wind's presence. On hot days you don't get a lot of wind.
/ /windmill water pump #12
This ones our favorite (insulated against freezing). Horses don't like ice water.
The next one is the most practical. It pumps air using a semi-truck auxilliary lift axle air spring. Air is sent to an 'air stone' in the pond which keeps a section open all winter. You can get 100+ psi out of this job if it plugs. Then she blows up the fittings.
/ /windmill water pump #13
I've used pex in low vacuum applications simply because it was on hand I've pulled 20in/hg on it but only in short sections.
Furrball idea #1:
Furrball idea #2:
Furrball idea #3:
-Jim​
Well, I think furrball 2 and 3 are out of the equation. furrball number 1 I find interesting, but not sure How well I like the ideal of making a air pump to drive a air motor to drive a pump to pump water. Seems like a lot of moving parts, but also sounds reasonable enough that I think I will spend a little time researching the ideal. Now one thing I do know is that a pvc water pump can act as a air pump, vacuum pump or a water pump. the design is basicly the same to do all three functions. If one could make such a system work, it would solve the problem of the pump freezing in winter therefore only have to worry about the pex tubing freezing and not the entire water system. One problem I see with using the pvc as a air pump would be wear on the pvc cyl and piston. dont know how one would keep it lubricated so as to not wear out in a week. While typeing this, I had and ideal for lubrication of the air pump assembly. basicly, add a oil tank so that as the piston runs up and down the cyl, it could pull oil into the cyl and push it back into the tank on the up stroke. Just have to figure out what kind of oil to use that wouldnt hurt the pvc pipe. Another ideal I had for the air pump would to be use a small hydraulic cyl instead of pvc pipe. since it wouldnt have any water in the cylinder, could be oiled using the same oil tank accessory for lubficationand would only need the addition of another port on the base end of cyl body. it would be very easy to put together. And I have some air cyl's I could convert just laying on the shelf in the shop. Any way, I am just rambling on with some of my own furrbar ideals. I havnt even seen the wind mill yet. Since bIL lives about 60 miles from me, it will probably be toward the end of next week before I can visit and I will take a camera to get a few pic.
ZZVY, I read your post too, I am sure I will have a few questions to ask you once I figure out what I have to work with. Right now its fun toying with different ideals, even if they do seem a little out there some times, thats why Necessity is the Mother of invention.
Everybody else, Keep the ideals coming.​
/ /windmill water pump #15
I do not know how deep your well is but if one has some depth below the water table, one can use a air lift pump, and pump air into the stand pipe and as the air rises it will bring water up as well, need a small stand pipe,
the geyser pump needs less depth of water,
look up Geyser Pump or air lift pump Airlift pump - Wikipedia, the free encyclopedia
a commercial made unit Submersible Pumps, Bore Pumps, Well Pumps, De-watering, Aerating, Leachate. DIY
and the picture is of a positive displacement pump, the problem is it needs some type of valve alternate the air and even dump the air, out of the cylinder, but one could possibly use two blow guns that would operate off the turning shaft with reduction that would run a set of cams that would work the blow gun vales, to blow air in to displace water, and one working opposite to dump the air so water can refill the cylinder with water to be pushed out again by air,
BIL came up for a visit today and we discussed some the options that have been suggested. I showed him a Utupe video of building a pvc pump so he is going to try to put one together sometime this week. He's sure of dead set on trying the pex tubing since he already has it and its leftover material from when he plumbed in his barn so it zero cost to try. We discussed the air pump ideal but not sure how to figure out the specs needed to make it work. I am currently leaning toward one of these type pumps, http://www.northerntool.com/shop/to...ontent=41763&gclid=CMW0zN-7v88CFVc6gQodZv0G0Q Not sure if making a air pump will produce the pressure needed to make it work. It takes a minimum 29psi and 10cfm to make work, I think it might be hard to get the windmill to pump that amount of volume or pressure with the materials I have on hand.
/ /windmill water pump #19
You can't use the air pump idea, you would have to buy more pex pipe wouldn't you? Or do you have enough to make 2 runs to the pond?
/ /windmill water pump #20
Nasty looking water they have.
The sign said it was an oil company...
If the motor runs on oil, I wonder if they have much of a net gain with that setup. Rube Goldberg works there, I suspect.
I found the sound effects very distracting...it sounded like somebody sawing wood by hand and pausing to crack a whip every few seconds!
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
