Windows 10
   / Windows 10 #11
How do you turn off those pictures that keep coming when you boot up that asks if you like or dislike them?? I can't find the switch!
Right click the screen and choose properties. You can select your own photo to come up every time.
   / Windows 10 #12
Now my next issue is when typing an email, and I want to change the color in the paragraph (it was easy before) from black to say green, no matter what I try it stays black. I can paint it, choose a different color, select it, but it still stays black...grrrr
Whats the secret to this one?
The secret is to not do things like that with email. Black text on a white background is the easiest to read. Don't mess with it.
   / Windows 10 #13
I would need to know what E-mail program you are using. Gmail, Outlook or what?
   / Windows 10
Thunderbird
It's when I want to highlight something in a sentence with a different color is what I'm referring to.
   / Windows 10 #15
See if your Thunderbird is version 24.4 or higher. If not upgrade it to current. This was supposedly fixed in version 24.4. If it is this or higher then you can try this
Thunderbird Menu Bar > Tools > Options > Display. Then under Fonts and Colors, selected Colors.
SELECTED : "Use system colors" and "Allow content to choose its own colors, instead of my selections above".
Selected OK
   / Windows 10
Selected OK
I have 43.3.0 version and I've tried what you suggested and selected always and never but it always defaults back to B & W.
   / Windows 10 #17
The latest version of Thunderbird is 45.3.0. This works for me: Write -> type text -> select text you want to change color on -> Format -> Text Color... -> click a color box -> OK
   / Windows 10
That's exactly what I've been doing, but it won't change color...stays black..
   / Windows 10 #19
Hopefully your screen looks like mine in Mozilla Thunderbird when composing an email. Highlight the text you wish to change the color, and click on the black box, (not the white) to change the text color. The white box will change the background color, not the text color. Be sure the text you wish to change is highlighted using your mouse.
Edit - After looking at Mozilla Help (typing "text color"), if the above does not work, Try the following -
On the top menu options, select "Tools-Options" then select the Display icon. Select the Formatting Tab. Lower right select "Colors" Be sure the listing "Use system colors" is unchecked.
That is how mine is setup. Good luck.
  • Color_Test_Mozilla.pdf
   / Windows 10
That did it, thanks. You have to change to never on use system colors though.
I swear, I'd been through that same routine a dozen times with no luck. I must not have had them in the right sequence???
Thank you very much guys for all the help and suggestions.
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
