Worst stuck pics
/ Worst stuck pics #201
OK, I've got one "stuck" photo. This UTV is now gone, but in the 7 or 8 years we operated it, I can only recall getting her stuck 3 times. This one was the worst. :eek:
That is a great pic!! :thumbsup:
I had to send the pic to my SIL,, he needs one of those rollers to make sled runs for the grandchildren!! :)
/ Worst stuck pics #202
My wife's 2WD Tundra stuck in wet grass on a slight incline. It is quite comical how this LA mud clogs the BFG T/A KO's so easily. Her traction control doesn't do much to help either.
If your wife was pulling that trailer,,,..... does she have a sister?
/ Worst stuck pics #203
Yep, the good Cajun girls get picked up quick though.
Here is her and her sister pulling hooks out of alligator stomachs.
My wife pulling gators in.
Some of the ladies skinning.
/ Worst stuck pics #204
View attachment 479587View attachment 479588View attachment 479589
I have found the solution for this very annoying problem. Get a set or two of trac grabbers. Saves having to get the tractor out.
Amazon.com: Trac-Grabber - The "Get Unstuck" Traction Solution for Trucks/SUV-Large: Automotive
/ Worst stuck pics #205
9870sts combine with a almost full grain hopper found a sink hole in the field. Couldn't swing the auger out and get a grain cart under in, so we pulled him out with the 8420 John Deere on the grain cart. Only one cut through the field and the tractor was following him in so we hooked the chain to the tractor and backed the tractor up pulling him out.IMG_0269.JPG
Let the new guy pack silage with the 4WD and he did not pack the bunker wall good enough and when he drove by it just slide right against the wall. That one was a challenge to get out. We used the pay loader to lift the rear first and pushed silage under it with a telehandler, then repeated the process on the front and were able to back it out finally.
/ Worst stuck pics #206
That looks pretty slick. My solution was to order a 4WD 2017 F250. Should be in OCT 8. I'll probably get some track grabbers for that though.
/ Worst stuck pics #207
You'll love that new truck.
It can never hurt to have some cheap insurance. Winches even better, especially if in some bottomless muck, but for a slippery road or small incline these are handy. Not for offroading per se, but I bet these will be useful some day when I'm stuck out in the sticks and would have had a long walk otherwise.
/ Worst stuck pics #208
I got stuck today. I've been stuck a lot worse, but it still slowed progress.
/ Worst stuck pics #209
Why do I see so many pics of people with r4 tires trying to go where ag tires are needed?
/ Worst stuck pics #211
snoback for some reason that link did not look very good here.... try this one
hmmm still didn't post quite right.. maybe has something to do with being logged into Amazon. Just enter Trac Grabber into your amazon login.
/ Worst stuck pics #212
Ahhh, those metal grabbers will look great after someone hits the gas and they come spinning out from under the tire at about 80 MPH. Prob OK as long as you aren't pushing and are at crotch level behind the tire.
/ Worst stuck pics #213
If only you had the bucket still on
Thats how I got it out. Hooked the bucket to my B7200 and drug it to this tractor and managed to get it hitched on. Hooking a bucket with SSQA to a immobilized tractor is quite a challenge. With the front axel buried that tractor is not going anywhere with the amount of pulling force I could deliver. Lifting it up makes a huge difference.
/ Worst stuck pics #214
Forks on the FEL would help you "back out"
/ Worst stuck pics #215
/ Worst stuck pics #216
A bucket is better. Forks lose too much leverage.
Depends on your curl to stuck ratio I guess. I've had better luck with forks.
/ Worst stuck pics #217
In this case it was all I could do with the bucket. The bush hog was starting to become a dozer.
/ Worst stuck pics #218
Happens to all of us sooner or later.
/ Worst stuck pics #219
4570Man's experience with no bucket, reminded me of when I got stuck with nothing on the SSQA. :(
Was able to push back a long way, but then got into deeper mud and could not move any farther.
Brought the stump bucket with the UTV.
First push back, it is moving now. :thumbsup:
More push backs.
It is unstuck. :D
/ Worst stuck pics #220
Xfaxman, wouldn't that have been a good day to keep the equipment in the barn?:)
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2013 Ford F-150 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2000 CATERPILLAR 322BL EXCAVATOR (A65053)
2000 CATERPILLAR...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
