Starts but quits
/ Starts but quits #1
BC4
Member
Cartersville, GA.
Mahindra
I have a Mahindra 2816.
It starts hard then does start but it quits. Kinda smokes more than it used to. Acts like it is plugged up.
I only have 180 hours on it. Nothing has changed and I have never had a problem with it.
I just replaced the air filter and no change.
Any ideas what is going on?
Bob
/ Starts but quits #3
Bob
Air leaking into the fuel supply?
/ Starts but quits #4
Water in the fuel and/or tank will cause this too. If you have a drain at or near the filter, open it and drain fuel into a clear jar. Check to see if there's water at the bottom of the jar.
/ Starts but quits #5
Diesels need air and fuel.
Lotsa black means really plugged air, or possibly unburnt fuel.
If a diesel is running and stalls, or can't make rpms, check fuel delivery.
/ Starts but quits #6
try it with the fuel cap off to see if the fuel vent is plugged.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2006 Sea Ray Sundancer Boat w/ Loadmaster Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
TANK MANIFOLD (A58216)
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
