lazermule
Just after filling. It's less than full a few minutes later. Have thought about seeing if I could put a larger diameter line on it. Not sure if it's worth it no more trouble than it is though.
If you inadvertently got trash In the tank, the line could be slightly blocked causing your issue.
I just picked mine up today and they dropped the tank and checked the sender and it all checked out. The tech said that the feed pipe between the two tanks is better than 1 1/2 inches in diameter so i'd think it'd equalize pretty quickly. They told me to continue using it and see is anything changes or if a TSB is put out on it. He said it could be an issue in the dash, as my fuel level reading just disappears from time to time.
Anyway, I got the 50 hour service done. I guess only an oil change is needed at this time? He said the hydro is at 600 hrs?
Also had the tires filled and picked up a set of pallet forks.
LM
