DEAD TOOLCAT!
/ DEAD TOOLCAT! #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Been using the Toolcat quite a bit lately in the woods with no problems.
While backing up just outside of the woods, a noise was heard underneath with several loud beeps given before shutting down on its own.
No error codes were given, and unable to start.
While trying to start, the transmission light blinks - similar to when the shifter is not in neutral, or when the arm rest is not in the down position.
Does any one have any ideas? I am thinking a wire might have been pulled off by a stick or similar?
Is their a way the toolcat can be put into neutral so it can be towed to get it on a trailer?
Thanks in Advance
Yooper Dave
/ DEAD TOOLCAT! #4
Maybe a bit of a long shot but check fuses under right front dash. In paticular check #14. Switched power fuse/20 amp.
/ DEAD TOOLCAT!
Checked (all) the fuses and everything was ok.
There is no error code - just the light showing the neutral shifter was not in neutral - but it was.
Any other ideas?
Yooper Dave
/ DEAD TOOLCAT! #6
Shifter is fairly easy to pull off. Check switch inside shifter for continuity. 2-4 hex head/torx screws and a double pole double throw switch. (Best i remember). Mine went bad once.
/ DEAD TOOLCAT!
Toolcat got fixed.
The Mechanic found a bad fuse with some testing equipment after I visually inspected all the fuses prior.
/ DEAD TOOLCAT! #8
That was a really good call on birddog's part:thumbsup:
Glad you had an easy fix Dave!
/ DEAD TOOLCAT! #9
Toolcat got fixed.
Don't feel bad.... after 35 years in electronics support roles, and two degrees in electronics, I still slap myself in the forehead every time I visually inspect a fuse, deem it O.K., then after futzing around with it for a while, check the fuse again, but with a meter, only to find it is bad. :mur:
:laughing:
/ DEAD TOOLCAT! #11
Do you recall what the symptoms were when your FPR switch went bad. My toolcat blows the fuse when in the park position and turn the key on. The fuse will not blow if in forward or reverse when the key is turned on but if moved to park the fuse blows.
/ DEAD TOOLCAT! #12
What series is your toolcat? My symptoms were the same as yours, not much I know. Just kept blowing a fuse when turn key on in park, And obviously you can't start it in F/R Is 4 wheel steer engaged? If so, disengage and try again. I say this because mine was related to a bad solenoid on the the same circuit. This will be a wild guess on yours obviously. You will need a schematic of that wiring, whatever else is on that circuit is where the problem is. Naked wire, bad solenoid , etc IMO. Get a good meter if you don't have one.
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2022 EZ-GO ELITE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A64194)
2015 SkyJack SJ86T...
SARLO (A64557)
SARLO (A64557)
(20) 3'x20.5' HEAVY DUTY INSUALTED PANELS (A65055)
(20) 3'x20.5'...
