Help Interpreting Wiring Diagram & Using Multimeter
/ Help Interpreting Wiring Diagram & Using Multimeter #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
Good Morning,
A cool crisp morning in SW New Hampshire BUT PLEASE SEND RAIN........
I'm trying to test out the voltage readings coming to the Stop Fuel Solenoid. I'VE attached the appropriate Wiring Diagram for my '05 JD 790 Production/Serial Number. Wondering if someone could walk me thru the Multi-Meter Red/Black Probe placements and readings I should get. I can see by my "un-trained" eye the White-Red-Black wire connector coming from the Solenoid connects to a Harness Connector - Solenoid White Wire connects to Harness White/Blue wire to "Time Delay Control Module" PN: M803344 + "K2" Fuel Relay. The RED coming off the Solenoid connects to Harness Green/White to "K2" Fuel Relay. If I disconnect the Solenoid Connector, place the Tractor in the Start Position, what readings should I get from the Harness side connector points. Please spoon feed me where I need to place the probes while taking measurements. If the readings at the Harness are good I would "Assume" (you know that they say about that) the Fuel Solenoid is Bad. If the readings aren't good then again I can assume the "Time Delay Control Module" PN: M803344 upstream is bad.......
  • 790 Wiring Diagram 1.pdf
YANMAR DIESEL 3TNV82A vs. 3TNE82A
Based on this thread went to the John Deere Parts Catalog to look up the PN for the Fuel Stop Solenoid. My Tractor is an '05 with Engine (as marked) "3TNV82A-LJNT". The Catalog lists PN: M806808 for the Solenoid & RG60092 for the O-Ring but there are REMARKS = (ENGINE MARKED 3TNE84 AND 3TNE82A). Can someone tell me what the "NV" vs. "NE" variation is. THANKS
/ Help Interpreting Wiring Diagram & Using Multimeter #3
Re: HELP INTERPRETING WIRING DIAGRAM & USING MULTIMETER
Good Morning,
Looking at this thread you'll see I'm trying to test out the voltage readings coming to the Stop Fuel Solenoid. In my previous post I attached the appropriate Wiring Diagram for my '05 Production/Serial Number. Wondering if someone could walk me thru the Multi-Meter Red/Black Probe placements and readings I should get. I can see by my "un-trained" eye the White-Red-Black wire connector coming from the Solenoid connects to a Harness Connector - Solenoid White Wire connects to Harness White/Blue wire to "Time Delay Control Module" PN: M803344 + "K2" Fuel Relay. The RED coming off the Solenoid connects to Harness Green/White to "K2" Fuel Relay. If I disconnect the Solenoid Connector, place the Tractor in the Start Position, what readings should I get from the Harness side connector points. Please spoon feed me where I need to place the probes while taking measurements. If the readings at the Harness are good I would "Assume" (you know that they say about that) the Fuel Solenoid is Bad. If the readings aren't good then again I can assume the "Time Delay Control Module" PN: M803344 upstream is bad.......
Looked at my jd4200 solenoid. Face on the three contacts mak a triangle. The apex of the triangle contact should be ground. Of course I noted and then promptly forgot the lead colour.
/ Help Interpreting Wiring Diagram & Using Multimeter #4
Good Morning,
The fuel shut off solenoid colors red, white, black are:
Red = Pull in coil
White = Hold in coil
Black = Ground
Make sure PTO switch is OFF. Tractor is in Neutral. Your meter is set for DC volts in the correct range for 12-13 volts.
Start by checking your meter across the battery to make sure it is set correctly. Red to +, black to - you should have 12-13 volts.
Next check the harness side connector that goes to black on the FS (fuel shutoff). Red to battery + Black to black harness connector. If the harness black (ground wires is good, you should get 12-13 volts.
Now check the wire that matches up to the Red of the FS, (Green/White). Black meter lead to black wire of the connector. Red meter lead to wire that matches Red (Green/White) of the connector. PTO OFF, Neutral, Key ON. You should get 12-13 volts. This for the "hold in" coil of the FS
Now check the wire that matches up to the White of the FS (White/Blue). Black meter lead to black wire of the connector. Red meter lead to wire that matches White (White/Blue) of the connector. PTO OFF, Neutral. Key START. You should get 12-13 volts for ONE SECOND. This is the "pull in"
coil of the FS
If Black wire test fails, repair ground, black wire connects to ground.
If Red wire test fails, I would suspect the Delay Module
If White wire test fails I would suspect Fuel Relay, then Delay Module.
If all wires test OK suspect FS
/ Help Interpreting Wiring Diagram & Using Multimeter #5
What he said... Z5, excellent explanation.
Zebrafive, PERFECT & MUCH APPRECIATED. I originally started this request for help under the "790 Sporadic Starting" before asking a PM to move it out to this forum for wider review, glad I did. I am not mechanically inclined so thank you for the detailed step by step process. If you go to the "790 Sporadic Starting" Thread you'll see a reply saying it would be very hard, almost impossible, to take readings as you described. I value your input. THANK YOU AGAIN for responding..........
Zebrafive, Thanks for the post,
I got a little behind the curve with two threads going at once, (I should have closed the old one "790 Sporadic Starting" right away after the PM created this thread on my request). :duh:
If I had I would have caught your post before I pulled the solenoid so now I'm faced with either disconnecting the starter tomorrow (per the old thread approach) and visually inspecting the Solenoid's plunger performance or re-install and going your route. I also mentioned when I manually pushed in the plunger on the solenoid I heard some slight gurgling noise.......
About your post, again THANK YOU for the detail, reads like a Fault Detect Fault Isolate (FDFI) Tech Manual Procedure which I need.........
You Wrote: Next check the harness side connector that goes to black on the FS (fuel shutoff). Red to battery + Black to black harness connector. If the harness black (ground wires is good, you should get 12-13 volts.
Question on the "Red to Battery" statement I'm getting a bit lost, my obsolete multimeter has (2) 16" test leads, in order to span that width I guess I'd have to connect a booster cable to the Battery + so I can place the probe on the battery + and Black to black harness connector ? I noticed you were very exact stating: PTO OFF, Neutral, Key "ON" or KEY in "START" Position for the other steps, this step is done with the tractor off.
/ Help Interpreting Wiring Diagram & Using Multimeter #8
Yes, tractor can be OFF to do this step. You are confirming the black wire to ground is not broken. If you have a test light it would also work. Clip to battery + then the probe to the black wire. Light should come on.
If your leads are not long enough a jumper wire may be used.
/ Help Interpreting Wiring Diagram & Using Multimeter #9
And make sure you use the right inputs on the meter.... You do not want your positive lead plugged into the Amperage position. It will blow the fuse in the meter.
tcartwri, Thanks for the reminder...... Because I'm weak in this space so I went on-line and found the User Manual for the old Multimeter. I checked it over, tuned-it, replaced the battery and read very closely the "Taking DC Measurements", I'm glad to report so-far-so-good but I do agree someone like me should be reminded of the simple things, you never know......I have to admit, I did wince a bit when I first placed the probes on the battery terminals, involuntary response.......
Zebrafive, I did the "meter across the battery" A-OK, 12-13 volts. Performed the "confirming the black wire to ground is not broken" A-OK 12-13 volts. Performed the ""hold in" coil of the FS" A-OK, 12-13 volts.
Now I'm at the juncture, visual check of Solenoid plunger or continue down the FD/FI Procedures you outlined. Since I have the Solenoid removed I want to first disable the starter. In a previous post, dieselcrawler recommended to remove the white wire from the starter, again, just to be sure I've attached a PIC of what I believe he is referring to. Once removed the starter will not spin with the ignition key set to position "START"......
Once I get confirmation on the White Wire (pictured) I will remove it then take your FD/FI Measurements to make sure the GAA-ZINS are coming in right to the harness and the Time Delay Module has not fail (Red Wire Test). If all is A-OK then I'll replug the solenoid into the harness connector and proceed with visual observation.....
QUESTION: Is there something special I should be looking for with the plunger retraction..... If that operates OK then maybe the gurgling I described with visible oil around the plunger shaft as I push it in indicates the solenoid is in trouble.
/ Help Interpreting Wiring Diagram & Using Multimeter #11
The white wire with the blue stakon looks like it's (1) not factory, and (2) hooked up to the battery cable terminal.
That is likely not the white I was referring to, but will check mine asap, and let you know.
/ Help Interpreting Wiring Diagram & Using Multimeter #12
I got a close look at my tractor tonight... and a picture. I've marked the white wire from your picture in yellow, it is the feed to the tractor electrical system. Mine is moulded into the battery cable, yours has the blue stakon (crimp-on wire connector, ring type in this case). I want to point out the connector at the bottom of the starter, circled in red. This is the starter trigger wire, disconnecting it will disable the starter. Mine has a male/female blade type with plastic cover connection in the wire a few inches back, follow the blue line in my picture.
I'm having issues uploading the picture. I will edit/add it to this post asap.
/ Help Interpreting Wiring Diagram & Using Multimeter #13
Diesel Crawler is he checking the voltages under load? by back probing at the connector? I've seen nasty voltage drops a crossed timer delay modules that only show up under load. Same for other wires. Your following things closer, it maybe in the steps. Don't want to side track things i read them pretty quick.
/ Help Interpreting Wiring Diagram & Using Multimeter #14
TD: Haven't gotten to the point of checking under load yet.
/ Help Interpreting Wiring Diagram & Using Multimeter #15
Knowing which contact does what you should also be able to determine continuity of the solenoid circuits by taking ohm readings.
Checked my extra solinoid this way and got ohm readings.
Dieselcrawler, truckdiagnostics, Egon, Zebrafive (so far so good)
Thanks for your input. Looking at the Wiring Diagram - I'm at a juncture in the testing approach to validate if the Y2 Fuel Solenoid, the A1 Time Delay Control Module or perhaps even the K2 Fuel Relay are BAD. In Dieselcrawler's approach, he suggested pulling the Solenoid (which I did) while it remains connected to the X5 Wiring Harness Connector and visually inspect the solenoids plunger retract under load (Key in Start Position). My request (because I am untrained in this space), Is there a way to disengage the starter so it doesn't crank + without affecting necessary power going to the K1 Start Relay, K2 Fuel Relay, the Y2 Fuel Shutoff Solenoid and the A1 Time Delay Control Module so Zebrafive's RED & WHITE Wire Voltage checks can be performed.
Once the starter is disconnected with the X5 Wiring Harness Connector also dis-connected, my approach is to continue down Zebrafive's Testing Voltage Checks. Hopefully the Red and White Wire Tests will PASS leaving the failure candidate = Y2 Fuel Solenoid. I would then reconnect the X5 Wiring Harness Connector & visually observe the solenoids plunger retract (under load) to verify it's faulty. I will report back once we see if the Starter can be disconnected. THANKS.............
Video of JD 4300 solenoid.
Just saw the posted video in the other/old thread....... Wow how easy was removing that Solenoid, I have to be a contortionist to get my smaller hands in there to maneuver and catch the 10mm bolts. I was surprised to see the amount of oil "lots" gushing out when he manually pushed in the rod/plunger. In my case when I pushed in the plunger, no visible oil, very clean, just a slight gurgling sound. Thanks for the video. I'm hoping in the future these threads will help someone else going down this road............
/ Help Interpreting Wiring Diagram & Using Multimeter #18
I would remove K-1 Starter relay to disable the starter. As others noted the white wire to the starter with the blue crimped on terminal looks like someone picked up 12 volts from the battery at that point. There is another white "trigger" wire for the starter, but pulling the K-1 starter relay will do the same as removing the correct white wire.
/ Help Interpreting Wiring Diagram & Using Multimeter #19
Good catch!
/ Help Interpreting Wiring Diagram & Using Multimeter #20
Finally... hope this works... refer to post #12 for reference.
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNGK26K97G305720 (A65563)
2007 Chevrolet...
2000 Sterling Rollback L9500 Series Truck, VIN # 2FZNEWEB1YAG12895 (A65563)
2000 Sterling...
2016 John Deere 85G Midi Excavator (A64553)
2016 John Deere...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
