New Holland 2120 will not start
   / New Holland 2120 will not start
Thanks
   / New Holland 2120 will not start #14
I don't think this is your problem but on my 2120 the PTO lever must be moved all the way back then moved slightly forward to allow power to starter. Probably an adjustment but also a slight anti theft feature.
Have you traced 12v from key switch to starter, through the neutral safety and PTO safety? Mine is a 1993 and has no seat safety.
Jim
I can not get the PTO to disengage. With lever all the back it is still turning, but making noise.
I have got it to start, by putting clutch in. I have been using it with PTO running. I tried leaving clutch in for awhile.
   / New Holland 2120 will not start #16
PTO must be a different problem, most likely mechanical (rust on shaft or linkage from not using?). Have you confirmed volts at key switch, then fuel solenoid, then starter solenoid? My slightly older rig has no clutch safety, just neutral and PTO. Newer models from New Holland have had key switch problems, solved with a new NAPA switch. What have you learned from tracing wires and voltage?
Jim
Everything is fine. I read a post about having to go slightly forward with PTO lever. That was all it was.
With clutch in, before I figured that out, I would get 12 volts at solenoid.
All is good. Thanks for help.
   / New Holland 2120 will not start #18
Jim
Jim,
I've had similar problems as Zerk and I'm willing to swap key switch. Do you know part number for NAPA?
Thanks!
It wasn't the key switch. Nothing was wrong.
   / New Holland 2120 will not start #20
There's something wrong with mine...maybe the key switch.
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
DEUTZ MARATHON...
2006 International Bucket Truck (A55973)
2006 International...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
