New Holland 2120 will not start
   / New Holland 2120 will not start #31
We checked PTO safety sw...no joy. Turn key to the left and glow plug light comes on and I believe the plugs heat up since it will normally start in cold weather.
   / New Holland 2120 will not start #32
I have a /2120 tractor ford and mine won't start and it will drain battery down while running and if I don't take battery post off it will drain battery and makes a clicking noise
I've got that goign too. I started this thread because, PTO lever was all the way back, and should be hair forward.
I have been having start issues the whole time. Left it in the woods 2 week started right up. One month with ground off, would not start. But thistime I turned key back and forth over and over again. Fuel solenoid clicks. Not sure if key is bad, since it doesn't do it in one spot.
I had been getting it to start putting it on charger 10 minutes. I have wondered if relay needs full voltage to pick up, and possibly a draw. But sat in woods for 2 weeks, just fine. Unhooked battery, so not draw, though was able to get to start by cycling key. Need to put meter on back of key next time. Though I just want to get it running and do something
US PORTABLE BAND SAW (A58374)
US PORTABLE BAND...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
