New Holland 2120 will not start
   / New Holland 2120 will not start #21
There is something wrong with mine...could be the key switch.
   / New Holland 2120 will not start #22
there is something wrong with mine...could be the key switch.
   / New Holland 2120 will not start #23
Sorry don't know the number. Mine has lived indoors plus has a cab keeping it dry. I would think NAPA could get you a switch if you describe the positions. Search function on this site is poor.
Jim
   / New Holland 2120 will not start #27
Jumpered solenoid. Started.
if it started when you jumped it to the solenoid, you have some bad battery cables and/or you battery has a bad cell.
   / New Holland 2120 will not start #28
Found it TC.
Thanks!!
   / New Holland 2120 will not start #29
Mine didn't start when jumped. cleaned cables still nothing. Battery is good in tractor and I jumped from my F-250 while running. Pulled starter and it bench tested fine. Not sure what else to try.
   / New Holland 2120 will not start #30
If yours is the same as my friends, for testing sake pull PTO lever all the way back and then push forward till slight click is felt. put both selectors in neutral, push in clutch pedal, turn key to run. Should hear a click and louder clack. Then turn to start. Other than that, idk other than to run everything down for voltage drops. When you turn key backwards from off position does it turn on glow plugs?
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
1996 International Water Truck with a Caterpillar Engine (A55315)
1996 International...
204549 (A52707)
204549 (A52707)
10' CONTAINER (A52706)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
