5045d question and problem
/ 5045d question and problem #1
jed1894
Member
Georgia
John Deere 5045D
Problem: Will not turn over (start). No click, but cluster lights and all other lights come on. Also blowing the 10a "start relay" fuse every time I try to start it.
Battery good. I can jump the starter and make it turn over but something is keeping it from starting. Checked pto- not engaged, all gears neutral. I'm thinking something in switch? Any ideas I can try?
Thanks , jed
/ 5045d question and problem #2
I'm at 275 hours on my 2013 5045D with no problems.
Hope I'm not on borrowed time.
/ 5045d question and problem #3
Unplug the thermistor, replace fuse & see if it starts.
Just did. Cranked right up. Un a little rough but it's running. Thanks. This site is great!!!! What happens if I just leave it unplugged?
/ 5045d question and problem #5
The sensor you unplugged is the cold start sensor. It's designed to alter inj pump timing in cold weather for easier starting. Other than engine running rough at initial start up probably nothing else will be affected.
Pick one up for $49 at John Deere today. Thanks again
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2016 Ram 1500 Crew Cab Pickup Truck (A61568)
2016 Ram 1500 Crew...
5x12 Bumper Pull Trailer (A61165)
5x12 Bumper Pull...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
