New Tractor owner in search of Diesel gas containers
   / New Tractor owner in search of Diesel gas containers #1
jrnyfan
Wellston, OK
2016 Mahindra 2538
I remember when I was young, I used to see green gas cans specified for diesel. I have been unable to find any now that I have purchased my first tractor. What I have found online are yellow instead of green and here in Oklahoma nobody seems to stock anything. Do I need a special container for my diesel or can I buy a regular red gas can and label it for diesel? Any help would be appreciated.
   / New Tractor owner in search of Diesel gas containers #2
They go by yellow now for diesel.
Blue for Kerosene, and of course red for gasoline.
   / New Tractor owner in search of Diesel gas containers #3
"Legally speaking", you MUST use an approved YELLOW container for diesel.
The codes for hazardous fuels/materials have changed since the old days. All newer diesel cans are yellow by statute. It's a good idea to buy a newer can anyway.
An officer or fire marshall "can" cite you for transporting, storing, or dispensing fuel into an unauthorized container... but you're not likely to run into that problem.... unless you live in the foreign country of tree-huggin' hippy statutes known as California.
On the flip side... should you find one of the old cans of a different color, you can still legally use it as long as it retains the original painted-on warning or stamped/emobossed designation.
   / New Tractor owner in search of Diesel gas containers #4
look on amazon plenty of styles and sizes on there
   / New Tractor owner in search of Diesel gas containers #5
I use yellow cans from RuralKing, but also have a red can with marking on it for diesel
   / New Tractor owner in search of Diesel gas containers #6
Tractor Supply has the same cans as Rural King (which doesn't seem to have any stores west of Missouri).
Thanks everyone. I will try Tractor Supply.
   / New Tractor owner in search of Diesel gas containers #9
Don't buy any fuel can with the spouts that have to push the nozzle in to fill. These are what most places sell now and you will spill about as much as you put in with those, that is if they work more than once. The one that I bought like that worked one time and then wouldn't open so I had to modify it to just use it without a nozzle (use a funnel on it now and just pour it out of the spout). Blitz makes some of the better ones with the squeeze handle if you can find them. They work slow but they don't leak or spill anything.
   / New Tractor owner in search of Diesel gas containers #10
No-Spill, in Kansas, makes a can with trigger that vents out the back. They actually hold five gallons, and have a handle in back. Also the opening is much larger than cheaper cans. Product Features Works well though a guant funnel and open spout is faster.
Blitz shut down in 2012, due to lawsuits over explosions. Opinions vary over whether they were actually defective or it was the owners who were defective.
Eagle and Just Rite make metal cans, with our without spouts.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
LOT: Steel Work Bench w/Contents, 40" x 75" (A59076)
LOT: Steel Work...
SCALES & PEA (A58374)
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
