What a nightmare, please read.
/ What a nightmare, please read. #81
I wouldn't want another tractor, I would want my money back. He could have the same problem with another tractor.
True...with any brand. And he'd still have to go tractor shopping all over again. :) If my arithmetic is right, it's already been four weeks. If the delivery date for air freight is accurate, he's almost there. Since the dealer seems to be doing his best, I'd hang in there awhile longer. He knows he likes the tractor. Once it's fixed, it may never give him trouble again.
/ What a nightmare, please read. #82
Three months ago we bought a new Mahindra 2538. We use our machines commercially to landscape and have always used Kubota but decided to buy a Mahindra because of the positive reviews and no DPF. All in all it's a very well set up machine. It has good power and is very nimble. The fit and finish is very nice. And not having a DPF is a lifesaver in a commercial application.
BUT, at 81 hrs the hydrostatic unit developed a leak at the input shaft. As of 9/3/16, 24 days since they diagnosed it, the tractor is still split in 2 at the dealer. Mahindra does not stock any pumps in North America, as our unit was the "first to fail" in the 25 series.
We were told the pump had to come from Asia and would be 30-40 days by air and 90-120 by boat!?!? Worst yet is Mahindras customer service is HORRIBLE. We still can't get a tracking number for the pump. It takes 4-6 calls and a full week for anyone to return calls and every time we finally get someone we are given the run around and a promised to be called back, never happens.
Before the leak we pulled out 2 pieces of metal slag that got stuck in the quick connects on the rear remotes. At the 50 hr service the suction filter was PACKED with metal. I have asked numerous time to see the inside of the pump and Mahindra will not let the dealer open it up so we can see if metal has gone through it. Mahindra say flush it and it will be fine. If metal made it to the rear remotes, it went through the pumps, and I just happened to catch those pieces at the right time. Who knows what has been going through it.
Our dealer is doing the best they can, but are getting very little help from Mahindra. They just keep telling us the service reps are overloaded with work.
So as of right now I can't say much for Mahindra.
I will be updating this thread as everything progresses.
*Miss spelled Kubota
If your suction filter was packed with metal at 50 hours and you were pulling metal out of your rear remotes, something terrible happened early on. Your problem started well before your HST started leaking. The source of all of this metal must be found. Perhaps it is out of the HST unit, but I doubt it. I'd want to look inside the HST before I put a new one in place. If the metal did not come from the HST, then I'd keep looking until I figured it out. And of course the entire transmission needs to be cleaned, as well as lines, pump, remotes, etc.
By the way, you guys that hook your new tractor to your old hydraulic implements (like I think we all do) are sharing oil with that implement and any tractor it has connected with. Sort of like STDs in the human world, we will call this Implement Transmitted Disease - ITD. I really doubt this is the cause, but a failed implement that is putting metal shavings into the oil will put that abrasive and damage causing oil into the tractor tank. The system is designed to capture and filter the oil, but just a heads up that you can introduce metal into a system absent a tractor mechanical issue. HST transmissions are much more fussy about filtration. It makes sense that they can tolerate less crud in the oil then a simple gear trans. But the fact that you were pulling metal out of your rear remotes makes me wonder if you were actually putting metal in through your rear remotes. It is possible, and if so this repair should not be on Mahindra's dime.
But whatever the cause, the part needs to be available. As to not having the part on the shelf in the USA, that is not normal for MUSA. They are pretty good at parts. If this is true and there is not another part of this story yet to be told, then I am disappointed. I would understand not stocking many HST units though as we have sold literally several thousand Mahindra tractors, probably half with HST transmissions and other than a couple of charge pumps on the 2015HST (years ago) I do not recall every having a customer HST failure. Failures are rare. But lets say they only stock 1 HST unit and somehow it got sent to another dealer the day before. In this current world we live, you can get any small item from about any of the major countries in a matter of 3-5 days. And as far as I am concerned, the customer is more important than the production run. Build one less tractor for inventory and send us the HST unit!
Hopefully you will have your part soon. Nice you have a loaner.
*Update*
I called the dealer today and they said the hydrostatic unit landed at JFK. BUT, now it has to go through customs (1-2weeks), then be shipped to Texas and inspected then to the dealer. It is with a bunch of other parts so their is no way of finding the package as I live 1.5 hrs from JFK and was going to try and get it. The fact that it's with other parts means that it was no special rush and basically nobody gives a crap when it will get here.
/ What a nightmare, please read. #84
In the arbitration cases it does make a difference when a loaner is provided as to urgency.
/ What a nightmare, please read. #85
*Update*
That doesn't sound right, I suspect they built a lot of "margin" into that time frame.
/ What a nightmare, please read. #86
Dave makes a valid point. It's important to find out the source of that metal. Simply replacing a damaged pump may only be delaying the next failure. The source of that free metal is where you'll find the root cause of the problem. THAT needs to be fixed as well.
/ What a nightmare, please read. #87
Some times a good deal is anything but.
/ What a nightmare, please read. #88
[snip]
[snip]
Makes sense, Dave. But, oh man, I bet you just ruined the day for a lot of us swingers. Any suggestions on how our tractors can practice "safe swaps"?
/ What a nightmare, please read. #89
Give a new meaning to "key parties?"
/ What a nightmare, please read. #90
I was afraid this would happen! I just couldn't think of a more accurate way to illustrate the point. Funny.
/ What a nightmare, please read. #91
*Update*
Not necessarily. Those other parts could all be on an urgent rush status too, going to other dealers across the country. It could be that was the fastest way to get your part on a shipment here.
/ What a nightmare, please read. #92
I wish you well in getting the parts and getting this issue solved. I agree with others, need to find the source of the metal and also make sure there is not more in the tractor just waiting to ruin the new pump or other parts. If you had some at rear remotes, did it get into implements that you have used?
I have called Mahindra 3 times today and left two messages for two separate people and nobody called back. It has been 8 days and six messages since the customer service rep said she would call me back.
It's 2016, I don't consider 4+ weeks to get a part any kind of urgent rush.
/ What a nightmare, please read. #95
:D I don't either. But that might be their best if they haven't started distributing parts for that tractor yet. Pretty pathetic overall, especially since it's a new tractor and new customer.
/ What a nightmare, please read. #96
i think we should all boycott Mahindra!
that 'll teach 'em!
I know I won't be buy one.
I'm happy with what I have !! (Absolutely NO support in NA on any of them ;-)
/ What a nightmare, please read. #97
If you don't mind, what county are you in?
/ What a nightmare, please read. #98
that 'll teach 'em!
One of the nice things about this forum is that we can voice our opinions. But I think this reaction is way exaggerated, although it may be in jest. I suppose you want to help a fellow TBN brethren, but keep in mind that we do not know the other side of this story. Not saying the OP is not straight up, but we have not heard from MUSA or from the dealer and we probably never will.
I think it is fair to say that parts should be on the shelf and calls should be returned. I agree. But when I call Mahindra, they answer. When I order parts I get them right away. Pretty much 100% of the time. So let's not let this get blown out of proportion. I did wait several weeks recently for some non-critical Kubota parts. The tractor was still in use, so no big deal...but it was about 3 weeks and it could have just as well been an important part. I'm not going to boycott or even get mad at Kubota. It just happens occasionally.
/ What a nightmare, please read. #99
I hope you get your tractor issues resolved sooner rather then later.
Sometimes the money you pay extra for established brands helps things run smoother when things go wrong.
Having said that, I know auto parts are often hard to come by for very late model vehicles from the big three. So maybe it's just that.
On a separate note. I ordered a relay from Eaton (BIG company). It took six weeks. Wrong one came. But the right one took eight weeks and a lot of crap being flung into the fan. And a whole bunch of "it's en route" during those eight weeks! Maybe it's just these wonderful times we live in.
I would love the phone # and person you were talking to. I already have the 800 number in TX and the # for Bloomsberg, PA.
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
