dk lug nut size
/ dk lug nut size #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I need to buy some 1/2" metric sockets. Can anyone tell me what size I'll need for the front and rear lug nuts?
DK40SEH.
/ dk lug nut size #2
Unless they have changed since my 2006 DK45, that will be sizes, plural. The 2 nuts are a different size than the 4 bolts. I'd have to check (if you don't get an answer from somebody else first) but I'd guess you'll need 19mm, 21 mm or maybe even 23mm. I have one of those T-shaped tire wrenches and have to keep flipping it around to get the right size match (or, close enough). Do you have calipers; a measurement would be easiest.
/ dk lug nut size #3
Well, I can't say for sure, and I do have the DK35se not the DK40se. so I don't know if they are the same.. but from memory, the fronts are 19mm and the rears are 22mm..
/ dk lug nut size #4
19mm and 3/4" are almost exactly the same size, FYI. I would personally buy a whole 1/2" metric set, but if you're just buying what you need, you can skip the 19.
/ dk lug nut size #5
I just checked my 2006 DK35, for both front and rears, the studs are 24mm and the bolts are 22mm.
/ dk lug nut size #6
If memory serves My DK 40SE is 24mm front and rear.
/ dk lug nut size #8
My local Kioti dealer stopped selling Kioti tractors 2 years ago. Where can I buy Kioti lug nuts (24mm) locally? I couldn't find the correct size at Lowes.
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
250 GALLON FUEL TANK (A64280)
250 GALLON FUEL...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
(1) UNUSED 12.4-16 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12.4-16...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
