New (to me) Miller Thunderbolt AC/DC
/ New (to me) Miller Thunderbolt AC/DC #21
/ New (to me) Miller Thunderbolt AC/DC #22
Try counting 1 1 thousand 2 1 thousand
That is only a short term fix. A guy is better off learning how to read the puddle. And learn how to anticipate what the puddle is going to do, so you can make corrections to control the puddle.
Wish I could duplicate. Dang !
Thanks! ;)
/ New (to me) Miller Thunderbolt AC/DC #23
Just starting off is OK get that down before puddle reading
I'm still learning, and really trying to learn to read the puddle. That was part of why I got the undercut...I figure that's just part of the learning curve. I ran out of time or I would have run a couple more beads with that new knowledge, and I think it would be better.
The goal with my practice isn't to get a good bead, it's to learn what it takes to get a good bead, if that makes sense. I figure once I learn to really read the puddle I won't have to think about timing, or what a chart suggests as an amperage setting, or most of the other variables....the puddle will tell me if I'm right or wrong, and the resulting bead will either confirm or deny it.
Then again, I don't know anything about it, so I could be completely wrong :laughing:
/ New (to me) Miller Thunderbolt AC/DC #25
Another thing is how your put the rod in the stinger put it in so it's on a 45 degree and wash the sides and don't worry about the middle.
/ New (to me) Miller Thunderbolt AC/DC #26
Most likely you will never be in this situation.
I've taken several welding tests, that when I walked into the testing booth. Duct tape was over all the gauges on the welder. First part of the test is to be within the wire / rod manufacture's specifications. If not, I got to go home early that day. Which is a good thing, so I could start looking for another job.:D
/ New (to me) Miller Thunderbolt AC/DC #27
I took make or break tests in the field never had duct tape on the readout of the welders .
/ New (to me) Miller Thunderbolt AC/DC #28
These tests were all for construction projects in the local Navy shipyards. The Navy did not do the testing, they sent us to a testing facility in Seattle.
I don't imagine I'll ever be taking any tests, but I certainly don't want to rely on anything other than experience and what I'm seeing!
/ New (to me) Miller Thunderbolt AC/DC #30
Here is my Miller Thunderbolt that I call my welding drag queen. These were sold by farm stores like TSC, Quality Farm & Fleet, etc. in the mid-1990's under a different name than Miller but it is in fact all Miller. Picked this up for $100 a few years back off craigslist. If things get tight, it would be the absolute last of my 4 welders that I would willingly part with.
Cool! I knew the same machine was also sold as a Hobart, but didn't realize they were also badged with other brands. That was $100 well spent on your part!
/ New (to me) Miller Thunderbolt AC/DC #32
Well done, G-Man. I've begun to try my hand at welding and I've enjoyed your "ugly beads" thread as well as this one.
I hope to never stop learning.
/ New (to me) Miller Thunderbolt AC/DC #33
Miller made the machines for other manufacturers but these models might have been before ITW owned both Miller and Hobart. Vertical up 7018 can be done more than one way. Some people pause at the sides longer and make what looks like criss crossing steps (usually lower amps), some people do shorter pauses with less pronounced steps and other people just weave side to side with barely a pause at all and just keep the rod moving. I've seen some vertical up 7018 on pipe that looks like it was roll welded in the flat position.
Thanks! I'm glad it helps more than just me :)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2007 FREIGHTLINER...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
30in. Forks and Frame Mini Skid Steer Attachment (A59228)
30in. Forks and...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
