Using a Kubota to Power a Generator for Extended Periods
   / Using a Kubota to Power a Generator for Extended Periods #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
The power grid in my area is unreliable and outages are frequent. I bought a small 2KW gas powered generator many years ago which is sufficient to run the furnace, fridge, TV and a few lights. It isn't large enough for the oven, stove, well pump, septic pump, freezers or A/C. Thankfully, most outages are fairly short duration and the small generator has served us well over the years.
In recent years however, we have been hit by larger storms causing extended outages. During hurricane Irene in 2011, we were out of power for 7 days. After we were out 8 1/2 days during superstorm Sandy in 2012, I bought a 13KW PTO generator for my Kubota. With a little conservation, it will power the entire house. I've used it for a couple of short outages lasting a few hours and the setup works well. Hurricane season is upon us again and with it, the possibility of another extended outage.
Has anyone had experience running a tractor powered generator for extended periods like 12+ hours a day for a week or more? Any problems like overheating, regen issues etc? Running the tractor at 2800 rpm continuously like that makes me a bit nervous. The dealer claims "running a generator is the easiest duty a Kubota will ever see". Still, he's the guy selling me the generator and perhaps a new Kubota in the future.
Obviously, the best solution would be a pad mounted whole house generator but the price is too high. Any advice or comments would be appreciated.
   / Using a Kubota to Power a Generator for Extended Periods #2
That is exactly how I ended up with the two-pronged approach I have:
Sandy -- 12 days without power: what worked, what didn't ... - AR15.COM
As you can see from above, from a fuel conservation standpoint it's a good solution.
wrooster
   / Using a Kubota to Power a Generator for Extended Periods #3
Your dealer is right...
SR
   / Using a Kubota to Power a Generator for Extended Periods #4
Do not worry about the tractor . Keep clean and proper fuel , cold weather , on hand . Do be aware of the PTO shaft at all times ! Kids , dogs , neighbors , like to get curious about running tractors . Diesel engines are designed for continuous duty like this . Are you going to need the tractor for other things while power is out ? Kevin .
   / Using a Kubota to Power a Generator for Extended Periods #5
If your tractor won't make it's rated pto power, and pto rpm, from full gas tank to empty gas tank, you bought the wrong tractor.
PS. During an emergency, you do realize that you don't need to run continously for 24/7 right?
You know. run it for a couple hours to charge batteries, cool refers, pump up some water, heat some water, etc, then shut down. Practicing normal conservation, and your pressure tank should keep toilets flushing and hand washing water for short time periods in between power ups. IE.. you shouldn't be using enough waste water to need the septic pump in between power ups.
water heated int he water heater will stay hot between power ups, and the pressure tank will give you pressure, so if you HAD to.. you could take a hot shower with power off.. etc.
During the 04 / 05 florida hurricane bonanza, I had a collection of antique fords that ran my 12kw genny as needed. off and on for a couple weeks.
when I was working on my farm before power was out there, my old ford 660 from 1955 ran that genny to do fencing and pump the well up for the animals stock tanks.
If that kubota can't do that.. sell it and get a real tractor!
( Hint... the kubota CAN do it.. )
   / Using a Kubota to Power a Generator for Extended Periods #6
wrooster
It's also the same approach I took, pto gen set for long outages, to run my whole house as needed, and a Honda 2000 to run the fridge and any heat I need, for short outages...
SR
   / Using a Kubota to Power a Generator for Extended Periods #7
It will work great until you loose oil pressure or spring a leak in your cooling system. A PTO set is great to have, but I would keep an eye on things. I always found myself listening intently for any sign of problems. I feel more at ease having a system that will shut itself down in case of trouble.
I guess I should have added a few more details.
The generator requires 35 HP and the PTO HP on my MX5800 is 50+ so there are no problems there.
I realize I don't need to run the tractor generator 24/7. the 2KW unit takes care of the nighttime requirements. However, since most of our long term power outages occur during spring / summer storms, my big concern is air conditioning. We have several elderly family members living with us who, for health reasons, are sensitive to heat. We run the A/C most of the day and switch to fans at night if required. The house heats up fairly quickly when the A/C is off.
I use other equipment for snow removal and have yet to need the tractor for other chores during a power outage.
@Wrooster, Thanks for the link and the good information. I guess I shouldn't complain. An 8 1/2 day outage is nothing compared to what some of you folks closer to the coast faced.
   / Using a Kubota to Power a Generator for Extended Periods #9
Sounds like you have a good system worked out, to me!
SR
   / Using a Kubota to Power a Generator for Extended Periods #10
Then get murphy switch gauges. .. then your machine can shut itself down if it sees a fault.
   / Using a Kubota to Power a Generator for Extended Periods #11
That is what I would (highly) recommend. Some years ago when we had our six day or so outage on account of the big ice storm, I had just got my current standby system. It developed a small leak in the rad, lost enough coolant to overheat and the machine shut down as designed. No problem. I took the rad to a butcher, that day, who cut out the bad core and I was back in business. Not happy about the slight loss of rad capacity.
   / Using a Kubota to Power a Generator for Extended Periods #12
hopefully it shut down BEFORE it overheated...
   / Using a Kubota to Power a Generator for Extended Periods #13
I can run my 50kW pto alternator off of my 22 hp lawn mower. That way I can still use the tractor for things guys write that you need a tractor for after a storm. I'm still waiting for that to occur. However, I can't cut my grass while I'm running the air conditioner, well, garage door openers, washer and dryer and microwave. Tv's and uVerse routers, too.
   / Using a Kubota to Power a Generator for Extended Periods #14
I don't understand why tractors don't have a shut down feature. OR, at least a LOUD signal. I contemplated this today, while using our open station JD during daytime hours. I would probably never see the indicator light for a serious fault, and wouldn't hear the alert, wearing ear protection.
   / Using a Kubota to Power a Generator for Extended Periods #15
In all the years we've had tractors on this place, we've never needed it, not even once... Then again, we don't run deere tractors... lol
I have NO problem leaving any one of my tractors run over night, without a baby sitter!
SR
   / Using a Kubota to Power a Generator for Extended Periods #16
A common automotive relay/socket (20-40a) can be used to trigger the horn or light of your choice. (opportunity to go a little crazy with triple air horns, sirens, strobes, etc ... and of course a 'test' button. :D)
More than one dashboard light can trigger the relay if a diode is properly wired (to 85/86) for each. Easy-peasy IMO, and OEM dash light function(s) would remain unchanged. :)
   / Using a Kubota to Power a Generator for Extended Periods #17
A common automotive relay/socket (20-40a) can be used to trigger the horn or light of your choice. (opportunity to go a little crazy with triple air horns, sirens, strobes, etc ... and of course a 'test' button. :D) More than one dashboard light can trigger the relay if a diode is properly wired (to 85/86) for each. Easy-peasy IMO, and OEM dash light function(s) would remain unchanged. :)
I'd use it to power a servo that flips the key off. On my older tractor I'd use it to pull the compression release. Why'd they stop putting a compression release on tractors? That will kill it under any circumstances. A key switch won't.
   / Using a Kubota to Power a Generator for Extended Periods #18
We have ran several tractors on out 55kw generator (dairy farm) and not scared to leave any of them run days on end. Just watch them and keep them fueled. Same with running our 2750 on the grain auger, never shut it off for up to a week of combining, just engage and disengage the pto as you pull trucks up. I will say though we have never ran a Kubota on the generator, due to the fact we had one 115 hp tractor for 6 months before we got smart and bought another Deere . But we have ran our 2750, 4450, 5105m, 6125r, 7530, 7420, and 8400 on it with no issues what so ever.
   / Using a Kubota to Power a Generator for Extended Periods #19
Our longest outage was around 6 days - ran a 15kw pto generator with the L345. It ran flawlessly for several multi-hour stretches. One thing I add is a drop light illuminating the tractor at night - its strange walking up to a stationary tractor turning 2000+ rpm in the dark. A neighbor shut it off once thinking it was left running by mistake :D
   / Using a Kubota to Power a Generator for Extended Periods #20
Man.. you guys want a million dollar answer to a 5 cent question.
For YEARS there have been gauge sets available that do what you want.
Google MURPHY SWITCH GAGE
oil, temp, etc.
hold bypass button to start, let up, then if oil pressure drops, gauge opens a circuit for you. that can be coil power to a gasser, or a fuel stop on a more modern diesel that has key-off.
If it's an older diesel, a fuel stop can be added, or a couple other options. no need to reinvent the wheel with robotic arms that reach over and turn the key off.. etc. :)
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2021 CATERPILLAR RM500B ROTARY MIXER (A60429)
2021 CATERPILLAR...
DEUTZ MARATHON...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
