HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #1
Scotty Dive
Ct
Yanmar 2020D
Let me apologize for this long thread but hope it will help many of us Yanmar owners out there who have or are planning on installing Power Beyond or Power Steering or a combination of both. However we are looking for feedback from any members who understand this stuff better than we do.
A little Background, I have an YM2020D with a V-Tek loader. My original loader valve did not have power beyond and the loader valve out port fed to the 3pt. This set up is very common on all of our loaders but there have been threads stating it is incorrect. My loader was responsive both upwards and downwards. Also, it raised with strength at low idle. 3 PT worked as it should. No issues at all.
Last fall, I installed the Hoye/Fredrick's Power steering kit and at the same time, I replaced my loader valve on my V-Tek loader. I installed a Brand Loader valve with power beyond and float.
Here is the diagram of how the hydraulics are hooked up with the new power steering and loader valve.
This was done according to the Hoye instructions except for the fact that instead of my loader out port going to 3pt (as it was originally) it now goes to the sump and the loader valve power beyond fed the 3pt. In the Hoye/Fredrick's Power Steering system is a FCR-51. The FCR is a Flow Control block allowing adjustment of flow to the power steering cylinder and the loader valve.
It is clear that since the Power steering is first in the flow that it takes priority and works well, however the adjustment in the FCR is very sensitive and you need to strike a balance between power steering and loader functionality. An adjustment a little one way or the other stops one of the systems from working correctly. I adjusted the FCR to a point where the power steering just barely works as it should. This setting is a 2.5 on a scale of 1-10. I believe this means, 25% of the flow goes to the PS and the 75% remaining goes to the Loader Valve in this set up. For example, adjusting the FCR to a setting of 3 and higher and you lose all loader functionality regardless of rpm and anything below 2.5 you lose all PS and the loader works at all rpms. At the 2.5 setting and at full rpm, I have both power steering and loader valve functionality. However, the loader response is slower and I lost all loader functionality at low idle where I had it before. I then upgraded to a 9cc pump (per the recommendation of Hoye) over the stock 7cc pump. With the new larger cc pump the loader hydraulics were quicker in response but still nonexistent at low idle. Another serious issue experienced was the loader dropped very quickly and violently when a heavy load was in the bucket. It makes finessing a load downward a delicate operation and risks damaging what is in or attached to the bucket and the platform you are dropping it onto. Before Power Steering and the new loader valve this was not an issue.
Now on to my partner in crime; Jtullis13, who has a Yanmar 2210D with a Koyker 120 loader and I have collaborated via PM and on the phone. This all started because he was installing the Hoye PS kit and I offered to lend my experience from installing the PS kit. Based on my shared experiences and what he experienced with his install, he began making a series of configuration changes to the hydraulic routing with varying results. After multiple changes, what he ended up doing is interesting and created a solution that is about 95% perfect. As he made port and flow adjustments certain results were experienced, like the 3pt not working when the loader was being used and the Power steering stopping when raising the boom arms and so on.
What he ended up with is this (his flow diagram is below). Instead of having the flow go to the FCR first per the Hoye Instruction, it flows to the loader Valve IN port. The loader valve power beyond AND the out port connect to a 1/2" Y valve (Purchased off EBay and rated for 10K psi) and the out port of the Y valve feeds the IN Port on the FCR. Let's discuss this logic here. We believe the flow to the loader valve (when the Joy Stick is in neutral (and not being use to tilt or raise/lower) flows through to the Power Beyond. When the Loader valve is being used the excess flow from the cylinders travels out the valve OUT port. By connecting these two independent streams they flow into one stream and provide fluid and pressure to the FCR at almost 100% flow. He set his FCR flow control valve at 7.5. The EX (Excess) port on the Flow Control valve returns to the Tank. The CF port feeds the IN port of the Power Steering. So 75% of flow goes to Power Steering and the 25% excess flow to the tank. Power Steering Out Port feeds the 3 PT. 3PT flows to the Tank.
Now, back to my YM2020D with Power beyond feeding the 3pt, we believe there is no back pressure (like there was when it flowed out through the Loader Valve OUT port to the 3PT) and is why I see the violent dropping of the loader when carry a heavy load. Jtullis13 also experienced this when using Power Beyond supplying the 3PT, but he has eliminated that because his system has some back pressure (we are guessing here) and therefore has much better loader control when lowering heavy loads.
Jtullis13's results are these: He has full use of the loader at all times and rpms. Lowering the boom or bucket with a load is controlled. Power steering works perfectly except he loses partial power steering when lifting the loader (makes sense to me because flow needed to fill cylinders) AND using power Steering. His 3 Pt works and has lifted upwards of 1000 lbs. with it. No whining at the pump. He plans on adding a gauge to his system which I am sure he will share his results if there is anything odd going on. I have one in my system and that's how I found out I was having spikes upwards of 5000 psi when the loader and 3pt were used at the same time. An adjustment of the 3pt fixed that.
So, Jtullis13's results are terrific and I am seriously considering making these changes but a bit hesitant because of my limited experience with hydraulics and not wanting to blow a pump out or worse. We both realize that not having Power Steering first in the hydraulic flow is a No No when it comes to cars, but we are not concerned about losing power steering in the case of a hydraulic power loss. At that moment we have more pressing issues to consider. Plus the steering will still work manually. The question is - is there something glaring that comes to mind that may cause issues with a set up like this?
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #2
What bad things happen or would happen if Jtullis let loader valve power beyond only go to FCR51 and let out port go to sump? Did he try that in his experiments? Just seems that would be the correct way. I guess you might loose power steering and 3 point while operating loader?
I believe your setup is as correct as you can get it. Problem may be just not quite enough pump flow for everything.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #3
Winston I have tried several different configurations before I decided to try this setup. The way Scotty described the setup and flow diagram is how I currently have it set up. As of now it works great. As Scotty described, my loader works great at any RPM, the 3pt works great, and so does the PS. The only catch is what Scotty described. I lose about 25% of PS function when raising the loader, and 3pt cuts out for a brief moment if I try to use it when using the PS at the same time. As for the pump suppling enough fluid, well so far so good. Like Scotty asked, does anyone see any potential problems? I don't at this time, but I'm not a hydraulics specialist my any means.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #4
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #5
Thanks for that link California, it does sound like he plumbed it the same way I did. As for your situation, I have a few other ideas. Since I've been considering a second tractor, initially the 1700d, which I decided against at this time, I had a planned to put PS on it even though there is not kit available for it. I figured out a way to make it work for anyone who is interested, hit me up later and I will explain.
Besides losing power to the PS, I believe you there is no back pressure to control a heavy load. I was moving a 500 # wood stove chaines tot he loader bucket and when I went to lower it, it almost crashed down. Almost impossible to feather it downward.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #7
Just seems the whole power beyond theory is abandoned with that senerio. Also don't understand needing back pressure to feather a load. Didn't think loader valves required back pressure to operate? :confused3:
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #8
I am going to answer this one for Scotty. Hope you don't mind and correct me if I'm wrong Scotty. So initially both Scotty and I like most others here with a loader had our loader outflow feeding the 3pt. I tend to believe that this set up puts some amount of back pressure on the outflow of the loader valve, resulting in a loader that drops with control (slower drop). I believe this because the flow to the 3pt goes through a series of channels before it goes to the sump. With the loader outflow going directly to his sump the loader had no back pressure, the fluid would just push out and into the open sump resulting in his loader dropping really fast. So configuring like I proposed Scotty to do and is what I did corrected that loader fast drop.
Thanks Jtullis - I called Brand and they are stumped as well. Not sure why both of our systems saw uncontrollable drops. Brand did confirm that the Power Beyond flows fluid at high pressure when the loader valve is not being used. The Output provides lower pressure return fluid from the boom and tilt cylinders. What that pressure is I don't know.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #10
No problem. All I know is that the way I have it now with the outflow being directed to the "Y" adapter as a secondary flow for the PS the drastic loader drop has stopped, and more controlled now. My reasoning is because it has back pressure now.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #11
My loader valve goes directly to sump .I re plumbed my this way. I don't know anything about back pressure, but I can feather my loader up or down.
I have posted here before How I plumbed my loader After adding the grapple. Input from pump to loader valve----out of loader valve to sump----Out of PB on loader valve to the input of grapple valve------out of grapple to sump-----out of grapple valve PB to 3 point.
I have factory PS ,and still have slow to no loader response @ idle.. @ About 1000-1200 RPM ? I have good loader functions.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #12
Thanks Kenmac. I do have a question for you, only because I haven't researched it yet. The question is, is your factory PS ran off your tractors hydraulic pump, or does it have its own pump & reservoir like a car or pickup?
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #13
comes off the tractor pump
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #14
Me too. Yanmar-USA dealer installed power steering just runs off plumbing under the seat, not from power beyond, same as the loader.
And I have that same issue: PS ok at any rpm, slow to no loader function below 900 rpm. (In contrast to the YM240 where loader and 3-point will lift at low idle).
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #15
Ok that makes sense why your loaders Kenmac & California are slow to lift at an idle. The PS is robbing the flow to your loader. I'm going to keep using mine the way I set it up as the way Scotty described in his post. So far no problems that I have noticed. Does anyone have any requests for me or Scotty to post about this setup? I'm going to try and take a few pics to post & maybe a video too for an example of how it works.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #16
yep, PS gets priority .I have thought about playing with it to see if I could make any adjustments, but it works ,and I just really don't think about it until I use the tractor
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #17
Yeah PS is suppose to get priority in setups like that and how Fredrick's & Hoye have it laid out too, and there is nothing wrong with it being setup like that, if you are ok with a slow loader. With he help of Scotty Dive, I think we have hopefully found a solution, just need more people's input.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #18
Mine isn't really set up like fredricks does it. He has from pump to loader valve, out of loader valve to 3pt. When I added the grapple, I plumbed mine differently but ps still gets priority. My think ps line comes out of a block on the side of the engine. I'll have to see if there's an adjustment at that block. I'm having a cylinder built on my dump trailer and need to get it back together 1st.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #19
Not the best video, but I showed the loader at very low idle, 1000, 1500, & 2000 RPM. Then I have my son on it using the loader and PS at the same time, he tried his best to follow instructions but not the best demonstration. Anyways he used it at 1000 rpm.
/ HYDRAULIC - Yanmar Flow for Power Beyond, Power Steering and 3PT #20
Well I guess the video didn't load, just the picture of my "Y" adapter. I will try again.
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
2012 International 4300 Reefer Truck (A63689)
2012 International...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
