Am I going to have to split my tractor to fix this?
/ Am I going to have to split my tractor to fix this? #21
Hose came off the fuel filter. This mower has always been feed ethanol free gas. The mower died and I got off to investigate. The muffler itself wasn't hot enough to ignite it. The gas was boiling off that. It must have gotten on the headers and it was hotter.
Craziness ...
Craziness ...
It gets even crazier. One of my buddies was giving me crap about it. Guess what happened to his mower the next week. It burned although not as bad as mine. He believes the fire started at the fuel pump, but it's really a mystery what happened.
/ Am I going to have to split my tractor to fix this? #23
Wow, I bet not so funny to him now..... It will be funny again after time heals the wound.
/ Am I going to have to split my tractor to fix this? #24
I got the steering column off the tractor. Hopefully I'll get it split tomorrow, but more realistically it'll be Thursday.
I don't want to ruin your day, but I believe you will need to remove the wiring harness from the front of the tractor in order to get the two halves split. I had to do it on my project. You'll need to start on the fuel solenoid side first. It wraps around the front of the tractor and goes toward the back on the alternator side. It isn't too bad to do. The connectors are all different for the most part so you really can't plug them into the wrong spot.
I don't think there is enough slack in the harness in the middle for you to be able to work on it otherwise...
/ Am I going to have to split my tractor to fix this? #25
My neighbor just started his on fire too. Actually a grass buildup over the muffler was the cause in his case, but the plastic hood was on fire and it's very close to the carb. Good reminder to clean and inspect those things and maybe mount a fire extinguisher.
I got it split! image-2093559509.jpg image-2012440365.jpg I also bought this.
/ Am I going to have to split my tractor to fix this? #27
Awesome job! Remember, if you jack up the housing by the throw out bearing, you will lose very little fluid. On the lower seal, I ended up taking a couple of flat head screwdrivers, heating the tips up with a torch and bending the very tip over 90 degrees in order to get the old seal out. This is also when you want help to have someone keep constant pressure on the end of the driveshaft.
I was also able to pack a bunch of grease in the throw out bearing. Use plenty of grease on the shafts also. We had trouble getting the 4wd output shaft seal back in. We found a piece of plastic pipe that worked, but I would have preferred to have been prepared before. Get yourself something that will fit over the shaft and will allow you to tap the seal in evenly.
/ Am I going to have to split my tractor to fix this? #28
Now it's my bad luck. Mine started leaking today - when 3 of us standing by the tractor and one noticed the puddle of oil forming. The thing is the oil dripping, or rather pouring, was black like engine oil. Is the oil from the seal described in this thread black by the time it makes it out the seal and down the case or do I have something different? L5740 with 850 hours.
Mine was leaking clear fluid that was definitely hydraulic fluid. The oil remains clear until it hits the ground. Check your engine oil. It wouldn't take long to drastically lower the engine oil level. At the worst it was leaking in a stream, but usually just a heavy drip. Running on the road ( in 2WD ) is when it leaked the worst.
/ Am I going to have to split my tractor to fix this? #30
If it is engine oil coming out of the clutch housing, then the rear main seal is bad.
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
KJ K4230G 42'x30' Metal Storage Shed (A60463)
KJ K4230G 42'x30'...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2016 KOMATSU PC360LC-11 EXCAVATOR (A60736)
2016 KOMATSU...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
